Results 1 to 10 of 25
Thread: Wheel Locking Nut Key Broken :(
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Wheel Locking Nut Key Broken :(
    Things have gone from bad to worse for me, all i wanted is to put my winter wheels on. First the wheel nuts are too tight, so then i brought a electric impact wrench from ebay to free it, that didnt work, when finally got the normal nuts loose, and try to undo the 3rd wheel locking nut the lock key broke. Can it get any worse.
    Anyone know how much its a replacement nut key from vauxhall?
    Thanks.
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    It's about 30 quid from vxl
    Your better. Going to a garage getting them removed and getting some decent locking nuts.
    Oct 2010
    LEICESTER
    ouch had the same prob cost me 26 fro a replacement key ,
    Nov 2011
    Swindon
    *Personally* I would take the locking wheel nuts off and throw them away.
    The vast majority of locking wheel nuts won't stop someone stealing your wheels, but will stop you changing them when you lose the key/break the key/Kwikfit guy destroys the key in his windy gun.
    Lancashire
    Quote Originally Posted by Betty View Post
    yes i agree with this , who nicks wheels these days they just take the whole car if they want something i cant remember the last time i heard of anyone getting there wheels swiped so i took mine off at least i know i will be able to get the wheel off on a dark motorway in ****ing rain lol
    South east
    You're supposed to remove the locking wheel nut whilst the normal wheel nuts are still in place, so they're holding the wheel against the hub and not putting pressure against the locking nut.
    Full Member
    Bristol
    If you have a car later than 54 plate vx have a complete set of duplicate keys to remove them and then give you a code to just buy replacment removing nut. So then get a cheaper set. If you get a nut removing agent to remove them without damaging you wheels , it will cost £25 per wheel. its cheaper to buy replacement key.
    Jun 2011
    brum
    which type you got? if you havent got the spinning collar types, get a normal socket, just a shade to small to go over, and whack it on with a hammer. I got my old man to grab one from work. Doesn't take too long , just make sure you knock them on square and not at an angle and you'll be fine.
    After each one i had to put the damn thing in a vice and use a thin bar to whack the nut out of the socket, so make sure you have something like a vice to hand. I jumped on a wreckin bar and used a scaffold bar as an extension on mine, so as long as you knock the socket on far enough, you can put as much force as you like on them and it wont slip (if it does, just whack it on even further and try again, took me 4 attempts on the first nut until i realised how much it needs to go on).
    You could also heat the nut up prior to this with a pencil torch or arc up on the nut with a welder for a few seconds, been told this helps, but i didnt have to.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by CritchvxD View Post
    Would places like kwikwit or ats be able to get it off.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by sb1uk View Post
    Its an 07 plate.
  1. Help Wanted : Wheel locking key broken
    By Envy in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2012, 13:13
  2. Fuel Flap locking mechanism broken? Help please
    By luke4487 in forum Bodywork & Interior
    Last Post: 26th June 2011, 16:35
  3. Broken locking nut key
    By LJ sxi-nav in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2009, 12:53
  4. broken locking nut key!!
    By shaneyboy in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2008, 02:13
  5. Broken locking wheel nut socket
    By Matt21385 in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2007, 09:45
