Thread: P0380 Fault Code
    Kent
    Default P0380 Fault Code
    Spanner light on which I identified as P0380 - there was no description to the fault code but I searched for the list and found this:
    P0380 Glow Plug/Heater Circuit "A" Malfunction.
    Am I correct in assuming this is the electronics rather than the actual glow plug itself?
    Its a Vectra 2.2DTI
    If the glow plugs need replacing is it an easy job or a garage job?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Does the spanner light go out after 30 seconds or so . If so then it probably is just a plug starting to break down .
    If any longer then it may 2 plugs on there way out or maybe the relay starting to let go .Best bet just change all the plugs at same time fairly straight forward just read up on the how 2 first for a few tips before starting
    and still loving it
    Kent
    I think it goes out pretty quickly, Ive read people have had them snap while trying to undo them which is what puts me off?
    Kent
    Just looked through the How to Section, there is only a how to for the 150CDTI could someone locate the glow plugs on the 2.2 DTI please
    Full Member
    Bristol
    Get your car warm and then spray with wd40 and let soak in for an hour then remove them I have never had one snap off. Test the glow plugs and they must glow at the tip not in the middle.
    Kent
    where abouts are they on the DTI?
    Engine : 2.0DTi
    Mileage : 73350
    Down below the rear face of the camshaft cover , plastic facia with 4 plug covers in a line these are the caps for the glow plugs , squeeze the top by the indent and the caps will lift off
    and still loving it
    Full Member
    Bristol
    Kent
    I'll have a look tomorrow see if I can identify them thanks
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    I had this code on my cdti and it turned out to be a bent glow plug, once replaced it was fine.
  1. Help error code P0380
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2012, 20:57
  2. P0380 Code
    By WeDesign in forum Engine & Drivetrain
    Last Post: 9th January 2012, 23:14
  3. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  4. fault codes p0070 p0380 help please
    By shelleps in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2011, 18:37
  5. P0380 fault code
    By frag45 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th December 2010, 09:15
opel fault code p0380-2
vauxhall p0380 fault code
vauxhall signum p380 fault code
p380 cdti vectra
OPEL P0380
P0380 OPEL
