Results 1 to 10 of 13
Thread: help with code/other car info
    Regular Member jimmywhu's Avatar
    Sep 2011
    essex
    Default help with code/other car info
    just got my car back from vx after putting her in this morning.... i took it there for a few reasons 1. when i went over speed humps i was getting this allfull noise from the front which does not sound very good it sounds like high creak and clonk even people where turning there heads while i was going over the humps.....
    there answear at vx is that its the front anti roll bar bushes?
    can some one inlighten me on what these are i google it and they say there £9-99 but vx wanna charge me £148 for them to be done? am i getting turned over.
    the second bit was when i brake i get like a vibration/grinding noise.
    vx said its fine but its not still does it and dont sound to good it sounds like as if you have no brake pads but hay is it just me?
    last and not least my spanner light comes on and off like like a yo yo so the code i got was P1191 they said it could be the fuel pressure regulator or fuel pump, as when i put my foot down and after 60-70mph i keept loseing power..
    if someone could help me with these as i no this is the best place to seek help and people on here explain in a easy friendly understanding so could some could spare me a lil help would very much be greatfull.
    if it helps i have a auto 2.2i elite direct on the 05 petrol
    stockport
    Exclamation
    I would try and confirm the code number they have quoted you as in my U480 OBD code reader handbook,it is not listed.FELIXX.
    Sep 2011
    essex
    see what i mean thanks FELIXX Ur a STAR
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Their probably trying to charge 2 hours labour for the bushes aswel.
    Brake could be as simple as a stone or the disc backing plate slightly touching disc.
    And lastly as above it's not a Vauxhall listed code.
    But I'm sure for landrover it's an oxygen sensor. Fault code.
    Maybe try an independent garage.
    Sep 2011
    essex
    THANKS CRITCHVXD with out you lot on her id be daffy ducked
    Sep 2011
    essex
    any more info guys?
    Sep 2009
    Audley STAFFS
    me car/spanner light has a mind of its own, I only have to change the brand of petrol and its on and off, BUT it says in my hand book," if this light comes on then goes off after a short while this is of no imprtance" so if it comes on and stays on,,problem,, or if car goes into limp mode,, problem,,, this daft light earns garages LOADS OF MONEY
    Sep 2011
    essex
    mine comes on then when u turn off and on it gos
    exeter
    the arb bushes are nothing to change .which will cost you £10 for the parts and buy 1 fexi 10mm rachet spanner. there is a how 2 on here . the grinding noise could be worn down to the metal pads grinding on the disk and finally on here someone has put all the codes up and your P1191 means Key Line Voltage .
    exeter
    i would check your code !!. what engine is it cdti or dti ?. because i know they both have egr valve faults .they get cloged with gunk . but for the diy person the dti is easy to do . because mine had the fault light come on and when i turned the engine off it went off. it ended up being the egr and inlet manifold cloged up . i had never done engine work before but i found 2 how 2's on here followed them and 2_3 hours later the job was done the car runs like new now
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Car tax info.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 23:33
  4. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
