Results 1 to 10 of 11
Thread: Can't get HID's to work??
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Default Can't get HID's to work??
    I have a set of 50w 4300k from HID's Direct. I have not hadthem working correctly yet. Had ballast changed and have 1 working ok. The other would not stop on for more than 5 mins but could be switched off then on again but goes out after a minute or so. Got this ballast changed but the problem has not gone away........absolutely fed up of taking the bumper on and off and thinking isc it possible they will not work on my car...or am I just unlucky with the kit supplied?? Gutte as when they work, there brill!
    Title should read HID's
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you using canbus friendly ones?
    Nov 2009
    manchester
    I had similar problem , i phoned hids direct and they said to swap sll components over from the one that is working ok and they will swap it, it turned out to be a faulty ballast , lucky for me i only live 10 mins from them so drove over and swapped it, they checked it first and confirmed it was faulty, hope this helps
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    It is the Vectra-C specific kit, i think built in canbus friendly. Comes with cancellors but doesn't seem to help. One is ok after changin ballast. Other has same symptom even after fitting new ballast....fine for 5 minutes then will not stop on They don't strobe or give any false bulb warnings, just won't stay on. Maybe i'm just been unlucky but it's a real pain keep swappin em over, paying postage to keep sending stuff back...not to mention dodgey headlights.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Sound silly but try fitting both cancellers to the side that doesn't work and see if that helps
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Quote Originally Posted by CritchvxD View Post
    Both inline?? The symptom is the same with or without cancellor, n/s works finw without.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Yes mate clip them together and just see.
    Sure a seen it. It may have been another forum someone done it and it cured their problem
    Jun 2006
    St. Helens,Merseyside
    can bus see's a fault and drops power to that light, ive just had this with the front fogs, had to get cancelers.
    argyll, scotland
    Did you ever get this sorted ??
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Quote Originally Posted by n8sby View Post
    Waiting for BST...won't be relying on headlights so will get them tested during daylight. Gonna do temp installation without bumper off....as absolutely fedup off taking the bumper off....5 different times lasrt year trying to sort problem....HID's Direct...no sympathy whatsoever
  1. HID's
    By McLovinH in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2012, 01:26
  2. Replies: 1
    Last Post: 6th July 2012, 21:52
  3. hid's
    By G4GAV in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 18:42
  4. HID's Once Again
    By JohnWilson in forum Styling
    Last Post: 1st September 2010, 21:46
  5. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
