Thread: Broken Thermostat & MPG....?
    North East
    Default Broken Thermostat & MPG....?
    I have read on other posts that some people think a duff thermostat can affect the mpg of a car, is this true?
    newport
    might certanly increased after i changed the stat on my 1.8. not a massive difference, but enough to notice
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by mpc View Post
    Yes on petrol not sure on an oil burner. If the ECU thinks the engine is cold then it sends in more fuel like the old style choke.
    You will find a cooler intake temperature from cold winter months will cause the MPG to worsen.
    scotland
    ^^ yip as above
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    when my 1.8 petrol thermostat had gone i was getting bad mpg
    now that ive had a thermostat it warms up quicker now and i get much better mpg
    may differ when really cold in the mornings needle goes between 87 to 89 when the temperature around 9 outside
    takes 3 miles to reach 87-89 and stays there. may move a little if you put it on heater 4 setting
    Jun 2006
    St. Helens,Merseyside
    can reduce the mpg quite a bit even on the cdti engine
    Full Member Big Sig's Avatar
    The car runs cold so it sticks more fuel in.
    Regular Member madman's Avatar
    nottm
    How long for a diesel to warm up on cold mornings? After 3 minutes I'm on the m1 for 5 miles at 60-70 and it only then begins to warm up
    Regular Member farmboy91's Avatar
    Aug 2011
    ipswich
    confused
    Quote Originally Posted by madman View Post
    mines b roads for about 11 miles at b road speeds and sometimes it hardly moves from the mark.....
    Jan 2008
    N/A
    68 Post(s)
    Vehicle : N/A
    Trim : N/A
    Engine : N/A
    Year : N/A
    also - change the temp control sensor.....this also contribute to bad mph if its faulty
  1. THermostat
    By les123 in forum Introduce yourself.
    Last Post: 31st July 2012, 22:43
  2. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  3. Think my thermostat has gone
    By e55ex_rob in forum Engine & Drivetrain
    Last Post: 6th December 2011, 15:30
  4. Thermostat
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 23:14
  5. Thermostat on 3.2
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 28th June 2009, 14:13
