Results 1 to 10 of 25
Thread: New MOT 2012 regs *worth a read*
    Oct 2011
    Essex
    Default New MOT 2012 regs *worth a read*
    http://www.dft.gov.uk/vosa/repositor...ce%2009-11.pdf
    The latest testers notes, pilthered rom the web. First off RFR I think means "reason for refusal". I have highlighted some of the ones that might catch you out, my notes are in (CAPS LOCK BRACKETS) these are live from January the 1st 2012:
    Quote Originally Posted by VOSA
    Annex B: List of New Testable Components
    Headlamp levelling and cleaning devices when fitted for HID or LED headlamps
     Main beam ‘tell-tale’
     Battery (including batteries for electric or hybrid vehicles)
     Electrical wiring and connectors
     Trailer electrical socket security and damage
     Operation of 13-pin trailer electrical sockets using an approved trailer socket tester
     Operation of the steering lock (where fitted) including that malfunction warning is not displayed for an electronic steering lock
     Electronic power steering malfunction warning indicating a fault
     Electronic parking brake control and malfunction indicator lamp
    Electronic Stability Control (ESC) components, including the switch (if fitted) and malfunction warning
     Brake fluid warning lamp illuminated or inoperative
    Tyre Pressure Monitoring Systems (TPMS) Oh dear Laguna owners!
     SRS components including airbags, seat belt pre-tensioners, seat belt load limiters and SRS (AIRBAG) malfunction warning lamp
     Engine mountings
     Speedometer
     Indirect vision devices (where they replace obligatory mirrors)
    Annex B: List of AMMENDED Testable Components
    Section 1 – Lamps, Reflectors and Electrical Equipment
    4. New note about front position lamps with a blue tint.
    9. Section 1.8 on headlamp aim now includes Methods of Inspection. (HID?)
    Section 7 – Exhaust, Fuel and Emissions
    1. Exhaust system checks amended and RfRs removed, for a part of the exhaust system missing (CATALYST?) or excessively deteriorated.
    2. New RfR where a catalytic converters are not fitted to vehicles subject to a full cat test.
    6. Diesel engine vehicles with a dual exhaust system fitted must now have the smoke assessed from both tailpipes and the readings averaged.
    7. Addition of 1.5m-1 smoke limit for vehicles first used on or after 1 July 2008. (BLACK SMOKE CLOUD???)
    newport
    Headlamp levelling and cleaning devices WHEN FITTED for HID or LED headlamps
    is that still saying, if its fitted, it has to work, but if they arent fitted they can't fail?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I see the Grey areas widening and even more uncertainty mounting towards the HID thing.
    Full Member
    Bristol
    Well that going to throw a few spanners in the works for the bright ones who have removed there cats and dpf filters. Happy new year expensive one at that. For all you non cat lovers.
    Quote Originally Posted by andrew e View Post
    I doubt this document is from DfT with that quote included in the form...
    It's all old news anyway
    I was wondering how long it would be before they added the point about checking BOTH tail pipes in a diesel, where it has a dual exhaust system
    One to note for the 3.0 V6 CDTI brigade
    So ask for both copies
    I wonder how many testers will get their calculators out!
    The smoke limit is a new limit
    It was tried before and was a disaster, about 80% of vehicles failed when it was first introduced
    Hence why most diesels now have DPF
    Quote Originally Posted by taffy bhoy View Post
    Correct
    It's the same with the other points in Annex B
    If fitted, then inspect
    The odd one here is the battery...
    If not fitted then cannot fail (although you will have difficulty with some of the other points)
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Speaking to the MOT test centre I've been at today they say they STILL HAVE NOT had any information on rule changes to the MOT. If these rule changes are supposed to be inforced by 1st January surely they should all be up to date.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Hyperhart View Post
    Neither the one I go to. Strange.
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    thats down to the garage, we had ours today, all the testers were discussing them over lunch
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Don't bother me for now, my MOT now expires at the beginning of 2013 so if they do come in I don't have to panic.
    Sep 2009
    Audley STAFFS
    my local garage has some of the info on his wall,ie,,,, tow bars even if you have a stow away or remove the tow bar the electrics plug still has to work, some of the rule changes happen later on in the year
  1. More regs
    By signum_rob in forum General Motoring Chat
    Last Post: 13th May 2012, 23:12
  2. Over 35? Worth a read.
    By Das in forum General Chat
    Last Post: 16th January 2012, 08:56
  3. 'ICE' (In Case Of Emergency) - Worth A Read
    By ccsnet in forum The 'Off Topic' room
    Last Post: 11th February 2009, 00:19
