Thread: Will new shocks soften my ride?
    Regular Member SteveBray's Avatar
    Barnsley, South Yorkshire
    Question Will new shocks soften my ride?
    I have these fitted to my Exclusiv 1.9 diesel:
    http://www.lmfvauxhall.co.uk/Apex-sp...-Vectra-C.html
    The ride over speed bumps, grates, dips and such is very bad, a real solid bang sometimes that makes me think something is going to break. I avoid as many potholes as possible but hitting some are inevitable, can I improve things by fitting new shock absorbers or is my ride quality impossible to improve due to the short springs?
    If I can improve the ride with new shocks any recommendations please?
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    well the problem with lowering springs is that it reduces the travel available in the shock obsorber, so you may find they are bottoming out, if this happens then they wont last very long, they are likely to leak, sag etc so if you buy uprated shock obsorbers they will be naturally shorter than standard so you have travel available withit coming to the end so it wont appear as harsh. it will never be as soft and comfertable as standard, the sacrifice for bettle looks and handling is ride comfort im afraid but shorter shocks should help. Id buy adjustable damping ones if you can stretch then you can find the setting which suits you.
    Thanks for that, will look into it.
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by Jaspa View Post
    The original shocks will only bottom out if the ride is lowered more than 50-60mm. That will require new shorten shocks..
    Loweringsprings will be harder to press because the travel length is shorter. That takes the driving comfort away from the car.
    35mm lowering could only cause shocks leaking if the shocks are old and rusty on the piston rod. Otherwise you willl be fine.
  1. Best Rear Shocks for Vectra C - Ride & Comfort
    By AirCooledHeaven in forum Suspension, Wheels & Brakes
    Last Post: 1st June 2012, 15:46
  2. Rear shocks fitted and ride height tweeked
    By A5TRA in forum Quick Photo Album
    Last Post: 15th April 2012, 16:25
  3. sri cdti estate can i soften the suspension
    By clyde in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:52
  4. Is there any way to soften wiper blades..?
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 18:04
  5. Mrs D's new ride!
    By Mrs D in forum Non Vectra C/Signum Album
    Last Post: 28th May 2007, 10:25
soften ride of vectra c estate
