Thread: Boot lock won't release
    Dec 2011
    S Wales
    Default Boot lock won't release
    My boot lock won't release either from the key or the button. The button has never beeped, though my previous pre face lift car did, but the boot still released. Now it's not releasing though the door locks all work fine.
    Any ideas?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is the motor actually turning when you press button on boot in?
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I had a similar problem to this a few months back and found that the wire that connects to the boot button and locking mechanism had vibrated loose.
    So had to climb into the boot to open it. Then strip all the paneling off to get acces to the mechanism. The connector was quite loose so I've now zip-tied it in place
    Dec 2011
    S Wales
    Motor works when you press the button on the boot; it makes a grinding sort of noise not the normal electric motor sort of whirr, so presumably power is getting to it. Should the button on the drivers door beep?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Think mine beeps yeah :-/
    But if the motor is turning its mechanically jammed can you undo it using the manual hole by lying in the boot and removing rubber grommet from just above the lock?
    Mine got to this point an would not budge I had to angle grind the lock off and replace it
    Dec 2011
    S Wales
    My God that sounds horrendous! I'll climb into the boot later this morning when it warms up a bit. Fingers crossed that WD40 might be enough. I'll let you know how I get on.
    Dec 2011
    S Wales
    Finally got round to doing the job; turned out to be something simple with a no-cost solution. Damo77 put his finger on it: the boot button operates a tiny microswitch to operate the lock. The microswitch is not very securely located in a plastic clip and can work loose preventing the switch from making. I only needed to secure the switch and a squirt of WD40 on the plunger for good measure and Bob's your uncle.
    Thanks to those who took the trouble to respond - much appreciated.
    Stoke-on-Trent
    Vehicle : Mazda 3
    Trim : Sport
    Engine : 2.0
    I had this problem a while back, I rang the garage and asked if they could look at it, but they said try leaning on the boot lid i.e. apply weight and press the button to release at the same time, sure enough that worked! I'm guessing its a common problem.
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Boot catch/release
    By pauldellboy in forum Bodywork & Interior
    Last Post: 16th July 2012, 20:32
  3. Remote boot release
    By RN37 VXL in forum Bodywork & Interior
    Last Post: 17th October 2009, 17:34
  4. Boot Release
    By DaveD in forum Styling
    Last Post: 14th August 2009, 10:18
  5. Boot Release
    By Drew in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 22:34
Vectra boot wont unlock just get whirring noise
boot release wont work on vectra
vectra c emergency boot release site:www.vectra-c.com
