Thread: Massive Electrical Problems with Boot Fusebox/module?
    Regular Member DTI Dave's Avatar
    Nov 2011
    st annes
    Default Massive Electrical Problems with Boot Fusebox/module?
    My car has now been at a garage for 2 days, it went in due to the brake lights staying on and no power to the washer pump. even with the brake light switch unplugged they still stay lit. They are now telling me they "think" the problem is the module/fuseblock in the boot, and want to charge me £300 for a new unit plus labour.
    on the same day the engine lost all power like the turbo wasnt even on the car, no boost, nothing..... a code reader told me there was a problem witht he boost pressure valve. This is the valve next to the passenger boost pipe, also used as a MAP sensor.... I took this out and cleaned it as it was quite bunged up, and still the problem persists.
    do i pull my car out of the garage?
    can any 1 give me serious help on this matter?
    Dave
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Have known a blown fuse to cause the brake lights to stay on before.
    Sounds like the pipe going to the turbo actuator has sprung a hole, last one i seen was melted to the downpipe.
    The fact that they 'think' thats the problem would be enough for me to take the car out of the garage and get it properly diagnosed.
    Nov 2011
    st annes
    All fuses checked out ok.
    the pipe you speak of is this rubber?
    yea im thinking about collecting the car tomorrow.
    Dec 2010
    Glasgow
    Mileage : Near 100K
    It was on a saab 2.2 tid ( same engine as dti vectras ) the pipe is part rubber and part plastic, could also be a blown intercooler or intercooler pipe, However you can normally hear the problem then.
    Nov 2011
    st annes
    a blown intercooler pipe would cause hissing correct? No hissing heard on this.. i did replace the passenger intercooler pipe with a silicone one on the same day.
  1. Damned electrical boot release
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2009, 21:37
  2. Help on electrical problems....please
    By Coby in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2009, 21:13
  3. Boot fusebox...
    By danBoy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2009, 18:17
  4. Electrical Problems
    By smellinglovely in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2009, 21:43
  5. Column Interface Module - Electrical Contacts
    By phil79 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2008, 18:41
vectra c brake module in the boot
