Thread: ignition problem
    Sep 2009
    St helens
    Default ignition problem
    Hi. I am having problems with my ignition. When I turn the key to position 2 all the lights and radio, etc come on but when I try and crack my car sometimes nothing happens and I have to turn the key back and forth until it starts. As a result of turning the key back and forth the airbag light has now come on. Any suggests on how to fix this problem. sonething to keep in mind, my heater blower has broke to. It only works on 4, I have tested the resister and control panel in another car and both work in that. Is this problem linked?
    Nov 2009
    N/A
    Quote Originally Posted by mattyj33 View Post
    Easy stuff first, check the battery voltage (I'm not sure the required voltage, but it should be around 12V),
    Does the engine make any sound at all? I know on mine when the battery is dead (reading 11ish volts), it tries to crank but not enough to turn the engine over
    Sep 2009
    St helens
    The battery is fairly new, but I will check it anyway. This problem seems to be more with the barrel than the electrics. Its like as though its not catching.
    wirral
    27 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sounds like a worn ign barrel
    Sep 2009
    St helens
    If I change the barrel will i need to change door and boot locks too?
    6 Post(s)
    Sounds more to me like the ignition switch is knackered rather than the barrel.
    Are they still mounted at the end of the barrel?
  1. new ignition car wont start problem
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:32
  2. ignition problem
    By gkr67 in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2009, 10:34
  3. Ignition coil and problem starting?
    By emptybee in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:36
  4. parrot ignition live problem
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2008, 23:18
  5. ignition problem can anyone please help
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 2nd May 2008, 19:27
vectra c turned key in ignition nothing happend
