Thread: common fault. so I thought
    Sep 2009
    St helens
    Default common fault. so I thought
    For the second time in 4 years my heater blower only works on number 4. So bought a new resistor, took out the glove box replaced the resister and...... Nothing. My first thought was dodgy resistor, so tried the new and the old resister in my mates car and both worked ok. so I thought it might be the control panel but that too worked in his car. So now I need ur help, what else can be the problem.
    Nov 2009
    N/A
    Quote Originally Posted by mattyj33 View Post
    Quite likely to be the relay (had the same problem on mine), remove the glove box, on the left hand side is the relay panel, there is a small blue relay about 1" by 0.5", replace that.... It costs about £7 from a dealer, you might be able to get cheaper from a scrappy or somewhere else (I might even have a spare one at home)
    Sep 2009
    St helens
    Cheers, will take alook at that at the weekend.
    Nov 2009
    N/A
    No worries, quick check - make sure the ignition is on, turn the switch to 0, when you turn to 1, you should hear a quiet click coming from the fusebox (if the relay is working), if not then that looks like the culprit!
    Oct 2009
    cheshire
    confused Help with heaters
    Help needed badly, my heaters only work on 3 & 4, tested he fuse link thats ok, cant be my switch because when i turn it to 1 setting i can hear the relay click, cant understand what it can be any ideas please (its frezzzzzzzzing)
    Sep 2009
    St helens
    Changing the relay worked perfect, only problem was the scrap yard didnt have a vauxhall one so i used a ford one instead and it work a treat
  1. Common Fault
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 00:13
  2. Mirrors fell off - another Common Fault
    By alcutler in forum Bodywork & Interior
    Last Post: 9th February 2012, 14:24
  3. Help Please, 2.2 DTi Common Fault?
    By chrisschild in forum Engine & Drivetrain
    Last Post: 8th December 2010, 11:05
  4. It appears its a common fault
    By gary k in forum Engine & Drivetrain
    Last Post: 17th February 2009, 10:34
  5. is this a common fault
    By don paul in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 11:21
