Results 1 to 10 of 11
Thread: Known software updates / field remedies
    Regular Member robster23's Avatar
    Hastings
    Default Known software updates / field remedies
    As the title suggests, I am hoping to compile a list of the above remedies and software updates known for the 3.0 so that I can beat the dealer about the head with them and get them done! All help greatfully received!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    The main ones relating to poor running are 1957 (SCV's on fuel pump) - dealer needs Tech2 to compare actual and desired fuel rail pressures.
    1831 - update of ECU software to reduce "whooshing" of EGR.
    There's a couple relating to oil pressure switch (1966) and oil pressure warning (1841), 1887 relates to blocked air vent/ breather on ECU box, 1740 (engine stalls during drive off and/or A/C compressor shut off at high loads).
    HTH .
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I regret having mine updated to software v.10. It ruined throttle response in neutral and holds on to the revs longer inbetween gear changes.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Celes View Post
    HIJACK !!!!!
    Have you seen this little baby? http://www.diesel-performance.co.uk/...ails.php?id=15
    Hastings
    That thing seems to just send a signal that the pedal is further down than it is? Wouldn't a tuning box or remap be better for that price?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by gtr1000 View Post
    HIJACK !!!!!
    I have seen that baby, but unfortunately I am yet to see £206.10
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    FR2226 Not sure on the exact TIS description, but got my car booked in for it in a fortnight. hopefully solve idle issues and misfire codes jumping from injector to injector.
    Regular Member ph67's Avatar
    Northamptonshire
    I had 2226 applied to my Z30DT a number of years ago, ,it would tickover and then shudder & judder similar to 'hunting' throw a car/spanner warning light with an error code P0301 (Cylinder miss-fire) - something to do with Small Quantity Learning - had it applied, it did make the throttle pick up slightly more sensitive on gear changes but you easily adjust to that but fixed the problem, never re-occurred since.
    Regular Member John Bishop's Avatar
    Oct 2010
    Quote Originally Posted by ph67 View Post
    Hmm. Mine has being doing the shudder and judder bit for about a month now but only when the engine is at running temp and for example sat at traffic lights but it does not throw up the spanner light. Plugged code reader in and nothing was found.
    Feb 2011
    Worcester
    And here it is:
    Field Remedy: 2226
    Subject: Engine Z30DT - Rough idle; DTC P030* set
    Models: Engines: Option:
    Vectra-C 2006...2008,Signum 2006...2008 Z30DT,Z30DT All
    Complaint: Rough idle speed, sometimes is a single trouble code P0301-6 set.
    Cause: Misfire detection too sensitive during SQL (Small Quantity Learning) process. SQL is performed automatically after certain mileage to identify and compensate injector tolerance.
    Production: New software for Z30DT expected in production as of October 2007.
    Remedy:
    In case of customer complaint program Engine Control Unit with latest
    software as of TIS 2000 DVD 84 (MT transmission ) and DVD 86
    (AT transmission).
    After programming carry out a small quantity adjustment via Tech 2.
    Do replace injectors only, if DTC reoccurs after reflash of ECU.
    Note: DVD 84 expected for End of August 2007, DVD 86 expected for end
    of October 2007.
    FunctionalGroup: J - Engine
    Complaint Group: 19 - Poor Engine Driveability
    Trouble Code: P0301,P0303,P0304,P0305,P0306
  1. Tech-2 & ECU software updates.
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 10:53
  2. Field remedies, applicable to the Vectra C
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 15:44
  3. Software Updates
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 14:05
  4. Field remedies
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2006, 17:50
vectra cdti ecu www.vectra-c.com
