Thread: water pump fitting / replacement
    Jul 2011
    peterborough
    Default water pump fitting / replacement
    am i right in thinking is that you have to remove a blank plate on chain cover fit some holding bolts in for the pulley , then can undo bolts for water pump .
    any other little tricks or advice ,
    oh its a 2.0t signum on 03 reg
    cheers
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Kirby,the 20Dti water pump replacment is a fair old job,its driven of the auxillary V belt,ther are quite a lot of parts to remove to gain acsess,coolant pipe ,Charge air pipe,air cleaner housing,engine damping block(you need to support engine to do this)pump V belt pulley and then the pump can be removed,as i said a fair old job.
    Jul 2011
    peterborough
    soz its a petrol 2.0 T , i beleive that the balance chain runs the water pump just wondered if was similar to the 2.2 as can see a cover opposite water pump & think u have to put some bolts in or something to stop this chain from slipping away but can then remove water pump
    Regular Member Mopar Man's Avatar
    herts
    Yes you need the tool that bolts on to the water pump gear.
    Jul 2011
    peterborough
    thank you , just googled & found it , by laser tool number 4791, all though been googling & searching forums & not really found much info on replacing the signum water pump
    Jul 2011
    peterborough
    Well it's done , reason for leak can only guess was due to corrosion on gasket mating faces as pump turned free enough,
    took me around 10 / 11 hours to do although this did include replacing me inner cv boot on d/side driveshaft as had to remove it for access .
    Also did it on a 2 post ramp so time lost lining up each day , poss saved time from struggling if car was on axle stands.
    Test drive tomorrow, but heaters & fan works & not dripping
    Bad parts
    putting rag in timing chain area incase water pump bolts fell between tool & pulley ,
    aligning new pump with pulley to bolt back up for which I used an old side broken mirror
    getting pipes of thermostat housing as didn't have right tool for unclamping clips,
    unbolting bit below Thermo housing & refitting it as forgot to put long bolt back in before putting hard pipe into pump housing & making sure tab lined up .
    driveshaft bearing & bracket need bolting together before bolting the bracket onto engine.
    Good points
    I did it , with knuckles in tact yep do wear gloves also
    Also found bolt missing in turbo nr oil feed pipe so may of found eml mystery
  1. water pump
    By GCusdin in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:16
  2. Water pump.
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 24th September 2012, 22:19
  3. Water pump 1.9
    By Kramel in forum Engine & Drivetrain
    Last Post: 15th July 2012, 12:12
  4. Water Pump Replacement Query Vectra 3.2 GSI
    By philgatt in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 10:48
  5. Water Pump????
    By Griff72 in forum Engine & Drivetrain
    Last Post: 19th August 2011, 00:36
vectra water pump bolt worn
