Thread: Heater direction settings
    Jan 2010
    EK
    Default Heater direction settings
    I seem to have a problem with the heating direction on Vectra SRI. This is more of an annoyance than a problem. When I have the dial turned to feet it's rather weak and doesn't heat your legs. It seems that setting does exactly the same as the Demister/leg blower. The other settings for Demister, face and face/legs work fine. No doubt this is happening on plenty of other Vectras but can anybody tell me if this is easy to fix or is difficult.
    Doncaster
    I've got exactly the same problem and am hunting around to try and find more info.
    Can anyone help us?
    Full Member Big Sig's Avatar
    Does the air come from anywhere else when you have it set to your feet? The next thing to check is the actual position of the diverter to ensure its letting air into the footwell.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Remove the centre footwell covers that will expose the heater and directional controls. Look for the actuators and the linkages to the flaps.
    When you move the dial you should see movement on the linkages and flaps. I would suggest that one is not functioning correctly.
    Shouldn't be difficult to rectify. If you find one servo isn't moving, before you condemn it to the bin, try opening the housing and testing with the motor not engaged with the plastic gears. If it rotates then check the gears themselves and also the flap lever. A bit of WD40 on the flap lever may help if it is stiff.
    Jan 2010
    EK
    Will give that a try as the other settings work properly. Regarding Big Sigs question the air blows through demister aswell as footwells at the feet only setting. I have the rear heater in car this works fine. I drive buses and funnily enough a fair number have the exact same problem demister blowing with 2 footwells even at feet setting. Must be me that's the problem :-)
    Jul 2009
    Norwich
    interesting. I have the same problem and have just come here looking for a solution. With mine it occasionally works when I use the car but most of the time it doesn't. Once it doesn't work it won't work no matter what I do until I turn the car off. sometimes when I turn it back on it works - but rarely.
    When I have it set to feet it usually blows straight at me or the windscreen It has always been very slow to change direction. I almost took it back when I bought it as I didn't think it worked but if I waited 10 secs or so it moved to the new setting.
    R.
  1. Heater Fan Settings
    By cae.dev in forum Troubleshooting
    Last Post: 3rd July 2012, 22:19
  2. Which direction is this car going?
    By Big Dave in forum The 'Off Topic' room
    Last Post: 27th September 2011, 09:05
  3. What direction should i go?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 21:36
  4. heater direction control knob problem
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 22:40
  5. Heater problem with air direction, poss canbus?
    By Wild al in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2008, 23:30
2010 vauxhall insignia heater direction slow
