Results 1 to 10 of 17
Thread: warning light
    Regular Member nicj's Avatar
    Jan 2009
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Default warning light
    Sorry another warning light question
    The last few days the vectra (1.9 CDTI) has been throwing the car with the spanner light on the dash. It goes off as soon as I start the engine. Any ideas what it could be? Drives and starts fine.
    Was fine until the bf decided to replace the resistors for the heater thing grr
    Jan 2009
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Sorry for being a tool but should i disconnect the battery for half an hour see if that gets rid?
    Sep 2007
    West
    as long as it goes out once the engine has fired up... theres no need to worry, this can be reset via a dode reader & maybe disconnecting the battery will clear it.
    Regular Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    Could be due a service and if its that you can reset it.
    only say that as mine is got this and its now due for 1.
    hope this helps.
    Sep 2007
    West
    car with spanner is not the service light... if it's due a service you will get "insp" in the mileage display
    Oct 2008
    Trim : leather
    Engine : 2.2 d
    Year : 2013
    Hi nicj. If the light is going off within seconds of starting the engine there is a stored fault code but the fault is no longer present and the light will eventually stop coming on, say after 20-30 starts. If the light is staying on for a few minutes after a cold start but going off straight away after a warm start it is indicating that there is a faulty glow plug or glow plug relay.
    Jan 2009
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Ah thanks guys you have put my mind at ease
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be a glow plug or the glow plug relay. I would settle for a faulty glow plug imo.
    Mar 2008
    slough
    glow plug
    Regular Member Signum-Steve's Avatar
    Feb 2009
    Cramlington Northumberland, V6 Jaguar S-type Sport
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Year : 2003
    Quote Originally Posted by Rapala View Post
    When your Bf removed the resistor a fault may of been stored. Once replaced the fault goes away but the spanner light comes on for a brief while to let you know that something was a-miss. You can get these cleared! Glow plugs are a posibility. However it's probably the resistor change that done it!!
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
