Thread: coolant already mixed
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default coolant already mixed
    is the coolant from vx already mixed or not? also any body got any tips on how to start a dti when airs in the fuel is it just the 4 th injector that you undo?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Not sure on the coolant.
    As for starting after fuel filter change, fill the filter with diesel and crank it for 20 seconds, then wait a minute, then try again. Took mine 4 attempts and it fired up. Use the accelerator pedal to keep it running for about a minute, to allow it to bleed through.
    If that fails, loosen injector 1 or 4 (can't remember which), and get someone to crank it until you see diesel coming out. Then tighten the injector, and it should fire up pretty quickly.
    I've never had to go down the injector route personally on mine
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    It doesn't come pre mixed.
    Give it a few goes on the glow plugs first by switching the ignition on waiting for the light to go out and ignition back off and then crank the engine over and crack a top union nut open one at a time until you get fuel coming through and lock it back up and stop cranking and then move on to the next one and do the same.
    Make sure the fuel filter housing is full with diesel first and the lid is on correctly and the securing bolt is done up tight.
    Oct 2009
    Sandwell
    up batterys been on charge all night it gave about 30 seconds of cranking and its dead. Scott this is getting pricey now mate lol new battery is needed i think. Just waiting on father in law to bring me some diesel and jump leads. I tried to play it crafty i called the bank to change my address to my moms address then called the aa out because im at home but the aa wont come out because i dont have home start. my next mod is a ****** hand primer pump
  1. Mixed day today
    By paddyvectra in forum The 'Off Topic' room
    Last Post: 21st February 2012, 22:16
  2. Mixed results
    By accveccysriturbo in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 20:26
  3. Mixed sex toilets...
    By spoons in forum General Chat
    Last Post: 15th June 2011, 13:00
  4. Mixed Grills!
    By keith1983 in forum Styling
    Last Post: 10th December 2008, 13:37
  5. Which pre mixed antifreeze to use?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2007, 11:38
