Results 1 to 10 of 15
Thread: Failed MOT :(
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Failed MOT :(
    Well it's failed. Funny enough it's only failed on 1 item.........emissions. 1.exhaust emissions carbon monoxide content after 2nd fast idle excessive. 2.exhaust emissions lambda reading after 2nd fast idle outside specified limits.3.exhaust emissions carbon monoxide content at idle excess. Trip to MIJ for a new cat I think as I had a decat in 2010 then had the centre silencer removed in early 2011.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Change the air filter and give it a good hard run at high revs straight before the test
    Engine : 1.9 CDTi
    Quote Originally Posted by tony-1977 View Post
    He doesn't have a cat fitted.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Being a GSi it shouldn't need the main cat due to the 2 precats, but it seems it does now (or could it be lambda sensors).
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Why did you not just leave the main CAT in and remove the pre cats? ON the CDTI anyway they are the most restrictive.
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    Quote Originally Posted by Gazza4 View Post
    lol do you want to attempt this? you are quite right if they can be removed it will certainly be much more restrictive but due to having 4 lambda sensors its not possible without cheating the downstream signals.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Jaspa View Post
    i asked why dont the pre cats just get removed? I wouldn't know what the ylook like on yours, The CDTI has one down pipe off of the turbo with the temperature sensor in it. There is a downpipe available and it has the hole for the downpipe. I'm sure if a few wanted this done a custom exhaust place would be able to make them up.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    This just gets better and better. Went to another MOT test centre this morning to get another emissions test done and it only flaming PASSED EVERYONE. Went back to the Vauxhall dealership and gave them the report and they retested it only to FAIL AGAIN. It seems that from yesterday to today the max limit for 02 has dropped from 0.300 to 0.200. Guess what Mr Motorbodies I'm not impressed and I certainly will not be coming back.
    Oct 2011
    Essex
    Speak to VOSA, its only an email - well you never know, times are hard out there £££....
    http://www.direct.gov.uk/en/Motoring...Mot/DG_4022113
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by andrew e View Post
    Thanks for that, spoke to vosa who confirmed that the CO limit is 0.3 and this morning Vauxhall set it at 0.2. I now have a full MOT with no advisories from a different garage so I will be asking for a full refund as my test at Vauxhall was done wrong twice.
  1. Failed MOT
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2011, 13:54
  2. EGR Mod failed
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2011, 14:59
  3. MOT failed :-(
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 20:14
  4. Vec failed its MOT
    By JusSRi in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2009, 19:48
  5. Tried & tried but failed doing what?
    By Tadpole in forum Bodywork & Interior
    Last Post: 4th May 2009, 19:26
2007 astra 1.8 failed mot on lambda readings
