Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Calling all cdti owners...................
    Aug 2010
    Leeds
    Default Calling all cdti owners...................
    It's coming the very cold mornings and the many many Thermostat threads on here will be many a week, so before we get to that stage what about.............
    Blanking off part of the radiator for a better warm up? Say about 35% of the radiator just behind the chrome plastic grill to see if this over cooled engine will heat up a little faster?
    Seen a few vw's with cooking foil over grill on taxi's guess there like the vectra and poor in winter.
    Im convinced the vectra (well 120 cdti) is like the sohc petrol Astra engine which is renowened for over cooling this year im blanking off part of the radiator only 35% as when stuck in traffic i don't want it to boil.
    7 miles to work last year at -6 and just got to 83c by the time i got there and the thermostat is fine in the slightly warmer weather.
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    Was also thinking about doing this but I'd read to cover half the front rad?
    My thermostat is working but takes 4 ages to heat up.
    Does any1 know the optimal engine temperature? (is it just below 90?)
    Also are there major problems of running cold apart from the oil not circulating great?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Since I changed the 'stat on my missus' 1.9 CDTI 150, it's up to 86 degrees within 4 miles of normal driving, even now with the colder mornings.
    My (slightly older) 2.2 DTi takes about the same time.
    That's without covering any part of the rad.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I hadn't thought about blanking, been through two winters as is. As far as temp goes, mine normally sits at indicated 85 degrees fully warm
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    If engine doesn't warm up to operating temperature, thermo is broken.
    Found this out for myself last year, and anyone else with this problem will find this out for themselves by changing the faulty part with a good one.
    Guarantee it.
    And to answer the question - the operating temperature should be around the 85-90C mark (some may differ slightly). Mine doesn't shift from 87C no matter what I do.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Blanking up the radiator isn't the best of ideas. It may be an over cooled engine but it definitely climbs in temperature to about 92C on idle in standstill traffic. Blanking part of the radiator is only going to inhibit the cooling effect here.
    The temperature on the CDTI should sit at 85-86C with a fully functioning thermostat, perfectly normal when driving. If it drops when driving the thermostat is on the road out or has failed. Normal for the temperature to rise within 5miles of driving from a cold start.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Quote Originally Posted by tony-1977 View Post
    IMO no need to blank off radiator. Just don't drive like you stole it until you have reached operating temperature. I went to diesel from a petrol, so I realise a bit of patience is required. LOL Mine sits at 83-84 degrees and sometimes drops a couple of degrees if I have been driving hard. As long as it starts rising at when the coolant temperature reaches just over 70 I'm happy.
    Regular Member jokerscrowbar's Avatar
    Nov 2011
    Pontypool
    If you have two keys then go and start the car, leave it running, lock the door and go back in and have a cuppa. Mine takes at least 10 minutes to get to 85C. Diesel drivers have been doing this for years and years.
    Really need a heated steering wheel though.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Have been pondering for a while whether to install a "Kenlowe engine preheater" but not sure if it can be used with the type of anti-freeze that VX use??
    My neighbour used to have one on his range rover and was always boasting about how he just sets the wall socket on a timer (hour before he leaves for work) and by the time he comes out in the morning the car is all defrosted and engine has been warmed up. No ice scraping and quite a nice warm'ish interior to get into.
    The ones I've seen are admittedly around £350 mark but if it helps warm the engine this would surely ease wear and tear at the same time as save all the hassle of de icing the car
    Only thing holding me back is, again whether or not I can use it with the VX type of anti-freeze, oh and cost
    Year : 55
    Mileage : 92,000
    Double post gremlins again
    Last edited by Damo77; 8th December 2011 at 03:46. Reason: Double post gremlins again
  1. Insignia CALLING: CDTI 160 owners
    By Vaux-Man-G in forum Insignia car chat
    Last Post: 26th October 2012, 00:58
  2. Calling all 1.9 CDTI Owners
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2009, 18:12
  3. Calling CDTi 150 owners
    By sdemps in forum General Chat
    Last Post: 20th March 2009, 21:35
