Results 1 to 10 of 11
Thread: Windscreen washer
    Sep 2011
    kent
    Default Windscreen washer
    Hey all..
    Vectra C 02 plate....
    The windscreen washers front and back have decided to stop working... thought at first it was just fluid so topped it up as you do but still no joy.. if you hold the lever to the on position long enough you get a very slight spray but it only just touches the windscreen? have also noticed the sound of the motor working has got quite loud compared to before...
    Motor need replacing or is there any other known faults? can't see much else it can be tbh...
    Regular Member smiler1982's Avatar
    Nov 2011
    Northampton
    Clean the filter out 20 min job easy peasy, its in the How2's.
    Does anyone know why my washers take a couple of seconds to work after pulling the stork? does my head in as it smears dirt all over my screen before it cleans it!
    Nov 2011
    Northampton
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine was like this when I bought the car. Cleaned out the filter and no joy. Got a new motor and it worked a dream. Can't remember how much it cost, but pretty sure it was fairly cheap, and it was from a main dealer
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by smiler1982 View Post
    Mine does this too. I've heard there's a one-way valve somewhere in the line? I've never bothered looking though. I just put up with it
    Nov 2009
    N/A
    Is there one filter for front or back, or a seperate filter for each? My front works fine, my back doesnt at all!
    Regular Member KevinG's Avatar
    South Bucks
    as everyone else, had it on mine, followed how2 on here, filter was completely covered in green gunk, easy job and they were like turning on a hose pipe afterwards (well all most)
    Regular Member KELLSY84's Avatar
    Feb 2011
    belfast
    you'll get to the bottle from the passenger front wheel. remove a few screws from the inner wheel arch and you will see the the washer pump pull it out and then clean the rubber gromet it pushes into. good luck
    11 Post(s)
    Here's the HOW2
    Sep 2011
    kent
    thanks guys, am going to give this a bash after lunch, have seen new motors/pump on the bay for under a tenna so cant be bad
  1. windscreen washer help
    By neill in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2013, 08:56
  2. Windscreen washer
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 21:33
  3. Windscreen Washer Jets
    By John Bishop in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2010, 12:46
  4. Windscreen washer problem
    By heheshamon in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2010, 14:54
  5. Windscreen Washer Motor
    By cae2020 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2007, 21:31
