Thread: Car has died!!!! Please help
    May 2008
    RAMSGATE
    Default Car has died!!!! Please help
    Its the vectra c 2.2 2002 Sri, it has had a bit of a lumpy idle for a while but tonight it died, just won't stay ticking over, it starts up then the revs go up and down then cuts out, have cleaned the TB and intake out, but in the inlet there is oil everywhere? Could it be this or the coil pack?
    Many thanks for any help
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    don't these engines suffer from a dodgy high pressure fuel pump?
    Nov 2009
    N/A
    Quote Originally Posted by Caveman_nige View Post
    (Assuming its a petrol, I don't know about the diesel 2.2) if its a 2002, its going to be a Z22SE (non-direct) engine which doesn't have a high pressure fuel pump (....If I'm reading the manual correctly).
    Though I'd have thought the fuel pump/filter would be a first point to check, check whether is there is pressure on the fuel rail.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Chain slip, fuel or might just be a rpm sensor
    Nov 2009
    N/A
    Quote Originally Posted by MORGIE8153 View Post
    Also if it was the coil pack, I'd expect it to either not start at all, or to run very badly on three (or less) cylinders! - Had this problem regularly on my old fiesta!!
    Covered in oil could be caused by a few things:
    1. at some point somebody has been topping up the oil and missed (depending on where it is)! - not really a problem, just a waste of oil!
    2. Oil leak somewhere, ie, knackered gasket/seal/head - If its just a gasket or a seal, not too much of a problem, just a case of replacing it (hopefully!), knackered (warped or cracked) head could be a bit more expensive!!
    Has the car been going through oil/coolant a lot recently/has it been burning oil?
    May 2008
    RAMSGATE
    Think it may be a chain slip, got a bad rattle coming from it too, had the rattle before on start up.
  1. cut out and died
    By mabski in forum Engine & Drivetrain
    Last Post: 1st March 2011, 10:47
  2. ?Has my Sat Nav died....
    By macdad in forum General Chat
    Last Post: 3rd March 2010, 01:49
  3. Help!! everything died!
    By Dai69 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2010, 15:37
  4. car died on me out of nowhere
    By WKD-mcc in forum Engine & Drivetrain
    Last Post: 28th February 2009, 16:03
  5. Car Died!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2007, 10:31
