Thread: Screen washers
    Rugby
    Default Screen washers
    Hi
    My windscreen washers seem to have lost all their power. It just trickles out onto the bottom of the screen.
    No leaks in the bottle, motor is working (can hear it). Any ideas????
    Jax
    How does the rear washer work compared to normal?
    Have you checked to see if the water is frozen?
    Four other possibilities if everything is normal
    Failed pump seals
    Replace the pump assembly
    Blocked washer bottle filter
    Replace the washer bottle filter
    Blocked washer jet assembly
    Remove and clean the washer jet assembly (although this normally only affects one, not both)
    Blocked pipe between filter and jets
    Disconnect the washer jet assembly, disconnect the washer bottle filter, and blow through the pipe, from the washer jet
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Blocked filter on end of pump intake.
    Not always, I had this last year and it was due to the bottle being partially frozen
    Rugby
    Trip to the garage I think, great!
    11 Post(s)
    Quote Originally Posted by Jax View Post
    No need for that. Filter is really easy to clean. Someone even did a HOW2
    Mar 2011
    Gateshead
    I had the same problem which turned out to be a small stone in the pipe blocking it, causing it to trickle out.
  1. Half screen to full screen,
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 01:13
  2. new screen now screen wiper problem
    By kenno31 in forum Bodywork & Interior
    Last Post: 18th February 2012, 12:34
  3. Headlight washers drinking my screen wash!
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 17:24
  4. Windscreen/rear screen washers kaput!
    By diesel dog in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 09:37
