Results 1 to 10 of 14
Thread: battery charger
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default battery charger
    anybody brought or got one of these to charge there battery up i brought the halfords one for £24.99 today but its going back if this is the same thing wich it looks like it is http://www.ebay.co.uk/itm/12V-BATTER...#ht_1100wt_952
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Just looks like a transformer to me? A proper trickle charger monitors the condition of the battery and tops it up accordingly, this looks like it will apply a charge to it all the time which isn't ideal.
    Oct 2009
    Sandwell
    Quote Originally Posted by keith1983 View Post
    the one ive got from halfords charges the battery and then when fully charged it switches over to maintenance mode so if the battery drops it will switch over to charge mode, so it says
    Engine : Z18XE
    So if you've got one from Halfords, how come you're looking for another one?
    Oct 2009
    Sandwell
    just looking at how much they were on ebay i brought the one from halfords because i needed it there and then but after reading your replys looks like the one ive got is a safe one
    also is this true
    A reading of 12.66 volts indicates a fully charged battery
    12.45 volts is 75% charged,
    12.24 volts is 50% charged,
    12.06 volts is 25% charge
    Engine : Z18XE
    I've no idea mate hopefully someone who knows better than me can answer that one!
    South east
    Quote Originally Posted by chris1804 View Post
    also is this true
    That's about right - but for a battery that hasn't been charged by the alternator for at least 12 hours, so don't measure it right after turning the engine off.
    Oct 2009
    Sandwell
    how long to fully charge a bettery? , im using the halfords wall socket with the 2 croc clips, the battery was dead i mean dead, its been on charge since 4pm tonight and just checked it its at 12.23
    sorry just re-read my post . how long to fully charge a bettery? depends on how big the battery is lol
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    General rule is charge a battery at 10% of its capacity for 10 hours.
    eg, 70 Amp Hour Battery, charge at 7 Amps for 10 hours.
    But 3.5 Amps for 20 hours is just as good.
    Or 1 amp for 70 Hours.
    But 70 Amps for 1 hour is NOT good. Battery plates will overheat.
    Oct 2009
    Sandwell
    old thread of mine but need some info, i haven't used the car for a good 8 weeks, well not enough to keep the battery 100%.
    i decided to dig out this halfords battery charger and hook it up to charge/maintain the battery. the spec on the charger says output:12vDC 750ma, im not an expert when it comes to electrics but wonder if somebody on here could tell me what rate this charger is charging the battery.
    if it helps the battery is a Exide 71Ah 670CCA
    (i did connect the multi-meter to the battery while charging and set it to MA and it read 0.06) not sure if that was the correct setting to tell me the charge rate,
  1. For Sale: Galaxy S3 Box,charger,Ear phones,Battery Team gb case,leather flip case
    By bigmac in forum General items for sale
    Last Post: 30th December 2012, 22:03
  2. Nokia Battery and Charger
    By @ndy-e in forum General Chat
    Last Post: 13th November 2009, 15:47
  3. Which battery charger?
    By Endlessdeep in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2009, 11:33
