Thread: Brake pad life
    Sodding Typical on Sea
    Default Brake pad life
    Just Curious, my car had four new pads discs and rear calipers when I bought it that was at 34,400 miles, I now have 56K and the pads are all still like new front and (I think surprisingly?) rear.
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    my rears were worn out after 20,000 miles fronts seem ok after 26000
    Yes, the original rear pads and discs are very poor performing
    You are lucky to get 20K miles out of them
    The replacements will last about 20K miles for the pads and 50K miles for the discs
    West
    I replaced all discs & pads with gm standard kits 2 years ago, 35k later i have just replaced all the pads again, backs were the reason for the change although there wasn't much life left in the front's... Not bad me thinks.
    Thanks guys, I do drive very sympathetically most of the time and am quite gentle on brakes unless I am in a strop and giving it the beans,,,,,
    Brake wear also varies by car type, typically the larger the higher the wear
    Equally, you can drive slowly and wear out brakes faster, lots of town driving will do that
    Finally, automatics rip through brake pads
    We have one on our fleet (driver requires this) and it has brake pads replaced about every 10K miles
    West
    mine is mainly town driving, over the last 12 month my average speed is 16mph.
    Oct 2011
    Essex
    Automatic 33k, original factory pads - plenty of meat on them still, I was surprised. You never can tell!
    Nov 2009
    N/A
    It depends very much on your driving style, obviously if you tend to brake late when stopping, pads are going to wear out faster, equally, town driving where your constantly braking for lights/crossing are going to wear your pads out faster, if you do a lot of motorway commuting, or plan ahead and use engine braking a lot, the pads will last a lot longer
    scotland
    85k on my 06 sig CDTI, still on original front discs and pads with around a third of the pad material left. Rear discs and pads were replaced for last MOT at around 80k, although the discs would probably have survived a little longer the pads were down to a couple of mm.
    These cars do weigh over 1500kg though.
    Confident the front pads will make the magic 100k mark if the rest of the car holds up till then
    Eddie.
  2. Brake pad life
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 22:38
  3. i saved the life of a life gaurd:)
    By the fisherman in forum General Chat
    Last Post: 26th September 2010, 21:25
  4. Brake pad life
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2010, 19:18
  5. Brake pad life
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2007, 14:52
