Thread: new member with a fustrating problem
    Dec 2011
    wirral
    Default new member with a fustrating problem
    Hi all i have had my vectra c for around 8 months (2.2 d elegance) i have recently changed my rear brake pads easy enough job but i have aquired a rather annoying rattle from the drivers side this along with the sqweeky altenator belt is driving me insane you advise would be appriciated!!
    thanks in advance
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Bet you bent dust shield when doing brakes just try and bend the dust sheild up slightly and make sure its not catching
    Irmscher Insignia CDTI 130
    Dec 2011
    wirral
    didnt think of that i'll give it ago thanks
    squeaky aux belt will no doubt be your aux belt tensioner
    easy fix
    Dec 2011
    wirral
    yeah thought as much will have to wait till after xmas already had to put a turbo regulator valve on it this month! and brakes ggrrr dust shield seems to have stopped rattle but will find out for defenate wen i drive to work later thanks fellas
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    Hi I had brake trouble when i did not use vauxhall parts on the rear rattle the pads moving around put vauxhall pads in job done all fine.
    scotland
    rear pads will just be 'ill - fitting pads ' plenty of coppaslip should sort it , aux belt ... rough up the smooth side slightly with som sandpaper should stop the squealing for a while .
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by martyparker View Post
    thanks in advance
    you need HYCOTE BELT SLIP,,,or any good belt dressing
  1. Hi there, new member with a big problem
    By DHR in forum Introduce yourself.
    Last Post: 6th June 2010, 19:47
  2. New member with old problem
    By inverkip1 in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 14:15
  3. new member with problem!
    By grandadwoody in forum Introduce yourself.
    Last Post: 23rd September 2007, 17:11
