Thread: Recommended 4 wheel alignment in Glasgow
    glasgow
    Default Recommended 4 wheel alignment in Glasgow
    Hi there ,looking to get 4 wheel alignment done on my xp vectra can anyone recommended a good place in Glasgow to get it done? Also what should I be looking for when getting it done?ive heard hunter is prob the best machine to do the job and weights should b put in the car? My knowledge is pretty much nil in this department.thanks for any help
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Have a look at the technical section in http://www.wheels-inmotion.co.uk/index.php to glean a bit more info on this subject.
    Then search the map on the same link and it should turn up a decent garage .
    East Ayrshire
    Trim : SRI XP1
    Pro-grip in bonnybridge, I travel through from Greenock. Definitely worth the few miles
    I have used McCocheneys at Speanbridge Roundabout
    Phone up and book an appointment
    Costs about £70 and takes just under an hour
    Take everything out of the car
    Put the car to the correct tyre pressures
    Ideally have about half a tank of fuel
    Sit in the reception, watch the screen and enjoy
    Engine : 1.9 CDTi
    Have a look at www.alignmycar.co.uk
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    As has been said before, Alignmycar do not endorse any particular garage. Their search function only gives a list of centres where they've supplied equipment to.
    Taken from their small print:
    "The alignment centres available on this site are all independently owned, and although they have been trained by Pro-Align on the use of their Hunter alignment equipment and given ‘best practice’ guidance, we cannot be held responsible for the wheel alignment service actually delivered.
    Please note that although we endorse the Hunter Imaging System, we are not able to recommend alignment centres, only provide guidance on their locations. All centres are independently owned and operate to their own standards."
    I went to several garages listed on the Alignmycar site only to find out the muppets operating the equipemnt hadn't got a clue about car geometry, let alone basic tracking .
    "Buyer beware" if you use the Alignmycar site .
    Yes, ran into that same issue
    The centre nearest me, Pro-Grip at Bonnybridge, had to search the database for my car
    When I contacted Hunters they advised their licence had expired, hence why they had to search the database
    When the outlet has a valid licence they simply entire the VRN and check / ask you if that is the correct car
  1. 4 wheel alignment.
    By Smithysvectra in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2012, 18:32
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. wheel alignment
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 10:57
  4. Recommended alloy repairer?Glasgow
    By gordy07 in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2011, 20:34
  5. wheel alignment
    By carl bear in forum Handling & Braking
    Last Post: 22nd November 2008, 18:36
