Results 1 to 10 of 23
Thread: Clutch died!
    Regular Member Matt_Bankier's Avatar
    May 2007
    Newcastle
    Default Clutch died!
    Yesterday whilst my fiance was driving to work the clutch on my 1.9 CDTI vectra has packed in.
    It has been perfectly fine right up untill she stopped at a roundabout, then the clutch pedal stayed down. The pedal does come up very slowly but i cannot disengage the clutch. To me it sounds like the slave cylinder has packed in, has anyone else had this experience?
    The car is a 2008 1.9CDTI Elite with 50k on the clock.
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Any noise / rattles in the months or weeks before it happened? If so suspect the DMF. As it's 2008 is it still in warranty?
    May 2007
    Newcastle
    No rattles or anything. Its been running sweet as nut. Just died out of the blue 10 minutes into her drive to work.
    May 2007
    Newcastle
    Well just had a quote from Vauxhall:
    Fitting new slave cylinder only = £594
    Fitting new slave cylinder and clutch kit = £968
    Fitting new slave cylinder, clutch kit and fly wheel = £1554
    Merry ****** christmas from vauxhall!
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Take it to an independant garage, might save some £££
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    does your car have a FULL Vauxhall service history.
    if so did you enquire about a good will contribution towards your bill ?
    if not, then i would be
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    could it be the clutch master cylinder?
    my bad, slave cylinder already mentioned.
    Christ!! they expensive
    VIP-Member MCD's Avatar
    NE Manchester
    30 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Matt, the DMF vauxhall supply is an LUK item, they supply it circa £400 with one year warranty. I got mine from autofactors... LUK item, two year warranty... £200, guess what? Exact same part!
    Go to an independent, it will cost you £800-£900 all in.
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP1 NAV - SUNROOF/AFL/CD70/XP2'd
    Regular Member 4eyes's Avatar
    Birmingham
    When you say the pedal comes back up slowly, have you tried pulling it back up?
    I've had this happen to me twice recently (once before with the missus) on start up and if you lean down and pull the clutch up and restart the engine, it works fine but the pedal feels spongy for a few pumps. After that, normal service is resumed!
    Not sure if that may help you - have you also fitted the clutch spring mod? I've got play in my clutch pedal slightly and think that the clutch spring mod has also stretched.
    Also had the Haynes manual out last night about it - have you had it confirmed the slave cylinder has gone? Might be worth bleeding the clutch first?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Even if it is just the slave your as well doing the clutch whilst the box is out anyway.
  1. Car has died!!!! Please help
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 9th December 2011, 17:00
  2. cut out and died
    By mabski in forum Engine & Drivetrain
    Last Post: 1st March 2011, 10:47
  3. ?Has my Sat Nav died....
    By macdad in forum General Chat
    Last Post: 3rd March 2010, 01:49
  4. Help!! everything died!
    By Dai69 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2010, 15:37
  5. car died on me out of nowhere
    By WKD-mcc in forum Engine & Drivetrain
    Last Post: 28th February 2009, 16:03
