Results 1 to 10 of 11
Thread: dti egr valve
    exeter
    Angry dti egr valve
    what causes the egr valve to clog up so quick . mine keeps doing it every 1000 miles .then i got to take it off and clean it and refit . i do that and the boost presure and the maf sensor. i dont want to spend £255 on a new one if i still get the same problem
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    have you tried to clean the whole manifold out
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by peadar View Post
    This is what i have said in the other thread
    exeter
    where and how easy is that to do ?
    Engine : 2.0DTi
    Mileage : 73350
    The top part of the manifold is easy , all you really need is a aerosol can of carb cleaner , the bottom half is a little more difficult , innes has done a how to on this part i see if i can find the thread
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i wouldnt be touching the MAF sensor they are very sensitive
    http://www.vectra-c.com/forum/showthread.php?t=145119
    exeter
    how much should a garage charge to do this lower manifold clean?
    Engine : 2.0DTi
    Mileage : 73350
    I personally would not give this job to a garage , just take the top part off and give that a clean , unless this is absolutely caked in crud then i would not consider doing the lower part . I have enclosed some pics of the upper manifold showing you what it looks like it also shows the boost sensor tip on the inside of the manifold this is only secured by the one screw and a rubber locking ring which can be easily prised off
    exeter
    i keep cleaning that .the last time i took it all of scrubed the manifold in the pic clean with a brush and then i used egr cleaner on the boost sensor and egr valve plus the maf . since then i have done about 1000 miles and i',m getting P0400 Exhaust Gas Recirculation Flow Malfunction code coming up again
    Engine : 2.0DTi
    Mileage : 73350
    Unplug the electrical connection on the egr and see if you are still getting the same fault code while there make sure there is no twists in the wiring and the wires are not stretched , i and others have had this before .
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
