Results 1 to 3 of 3
Thread: Map lights change
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Default Map lights change
    One of the things on my To Do List is change my roof light unit with one with individual map lights, but I have found that there seem to be two different versions; one has three buttons (two reading lights and one 'all lights on/off') and the other has four buttons (as above but with extra switch to turn entire unit on/off).
    Can anyone tell me whether both are openly available still and if so what are the relevant part numbers, if you know?
    Thanks, James.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the one with 3 buttons the 3 button turns on the normal interiur lights on.. the one with 4, can turn of the front light off when the door is open.
    you can find them on ebay or eg. lmfvauxhall
    Feb 2011
    Selby
    Go for the four button one if you can.
    I've got the three button one and it's very annoying. The two map light buttons turn them on and off, that's fine. But the other button only turns the main interior lights on if they're off (ie doors shut). There's no way of turning them off other than shutting the doors (or waiting 20 minutes for the battery protection system to shut them off).
    The four button one as stated above, has a button to turn off the interior lights.
  1. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  2. rear lights change
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2012, 11:02
  3. Replies: 2
    Last Post: 31st March 2010, 13:30
  4. How to change Vectra estate rear lights.......
    By James54 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2008, 10:33
  5. change interior to blue lights
    By dawsy in forum Styling
    Last Post: 7th September 2007, 05:00
blue lights vectra c map
vectra map lights replace
