Results 1 to 10 of 13
Thread: Loads of trouble codes - help!
    Birmingham
    Default Loads of trouble codes - help!
    Folks,
    As my Siggy (2.2 DTI Design/2004-04) is being a bid weird with the electrical issues (my other thread), I thought id run a code check on the ECU.
    This is what it has thrown up.
    Can someone please offer some help on this? There are loads.
    Thanks, G.
    Bye bye Vec B
    - Hello Siggy!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would clear the codes and see if they reappear, could be some of these are quite old.
    Birmingham
    I have cleared them, took it for a drive and re-checked, nothing yet. I didnt have any EML lights on the dash, this was just a precuationary check.
    Bye bye Vec B
    - Hello Siggy!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Have you had a flat battery recently
    and still loving it
    Birmingham
    Quote Originally Posted by bobssignum View Post
    Not flat, just the below lot as per the original thrad:
    Symptoms:
    - The radio/stereo intermittently turns of and comes straight back on (almost like someone pressed the power knob and then back on - doesnt request code after it restarts);
    - The centre displays flickers like mad, you can even see the pulse when the indicator is on;
    - Yesterday, for no reason at all after 5 hours of standing it struggled to start, almost as though the battery was dying. Once restarted it was perfect and was fine this morning and all day today;
    - Earlier this morning, as I put the ignition on the "Check Safeguard" message appeared in the central display and it sort of chugged before it started but then it was OK and the message dissappeared too.
    Bye bye Vec B
    - Hello Siggy!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Bad earth somewhere? Is there a cable strap from the chassis to the engine? Might be worth checking the condition if there is
    Birmingham
    Quote Originally Posted by merikiito View Post
    I deffo think its a bad earth as my stereo just keep flicking on and off. Now I have noticed that when the car is off but the ignition is on, the heater blowers also start to flick on and off.
    I have taken the stereo out, the centre display out, the speedo cluster out and have checked all connection, checked the earth points behind glovebox and all of the above are OK.
    |Im baffled.ill check for an engine earth too now.
    Bye bye Vec B
    - Hello Siggy!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    check the battery terminals are all tight and that all the fuses are ok as there might be a loose one
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I seem to recall some old opcom software bringing up silly faults on my old dti then tryed it with a newer version and they wasn't there
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    The codes with 'B' prefixes are usually linked to the Body Control Module (BCM). This itself could be issue if other basic checks of wiring, plugs/fuses come back fine. Four of those fault codes relate to the security system. How weird is it acting? Is it suffering bouncing central locking etc? (Central locking which can unlock itself), IS the alarm occasionally oging off?
    Ultimately the BCM may be playing up.
    Insignia VX-Line Nav CDTI 170.
  1. HELP PLEASE - Trouble codes: P1105-FA and P0105-FA
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 27th November 2015, 14:37
  2. help with trouble codes on a vectra 2.2 dti
    By deano1 in forum Engine & Drivetrain
    Last Post: 6th September 2012, 20:08
  3. GM Diagnostic Fault/Trouble Codes
    By GazVXLINE170 in forum Troubleshooting
    Last Post: 26th November 2010, 01:07
  4. Vectra-B TROUBLE CODES
    Last Post: 16th May 2009, 19:21
  5. Trouble Codes-Need HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2009, 16:43
