Results 1 to 3 of 3
Thread: Plumbing advice needed.
    Regular Member chrissri82's Avatar
    Apr 2009
    airdrie
    Default Plumbing advice needed.
    hi all. im about to attempt to replace my kitchen tap with an almost identical one.
    what i need to know is do i need to drain the water tank or will i get away with just turning the water off.
    thanks in advance
    chris
    Regular Member sol's Avatar
    Farnborough
    Engine : 2.0T
    Mileage : 63000
    You need to switch off the incoming mains stopcock (cold supply), and then also switch off the cold fill to your hot water tank. Once you've done that, you may need to open the taps to let any water still in the pipes drain out.
    As long as nothing is coming out of either tap after you've done the above, it's safe to remove it.
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    Hopefully there should be stop valves under the sink for both hot & cold supplies, if not close cold water main valve , hot water if tank feed shut feed off and run all hot taps will empty quicker , remembering to close afterwards. If supplied from combi boiler then just close or switch off cold water feed.simple.
  1. Replies: 28
    Last Post: 16th October 2012, 21:23
  2. Plumbing Advice Needed..
    By Jezzy in forum The 'Off Topic' room
    Last Post: 6th December 2009, 22:24
  3. Emergency plumbing question
    By craigbarlow18 in forum The 'Off Topic' room
    Last Post: 4th January 2009, 20:58
  4. Small Plumbing Question
    By Damian in forum General Chat
    Last Post: 15th May 2008, 19:52
  5. plumbing advice
    By John35 in forum General Chat
    Last Post: 20th August 2007, 22:02
