Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: z19dth broken cambelt
    Jul 2010
    Londonderry Northern Ireland
    Default z19dth broken cambelt
    What sort of damage should i expect?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    How fast were you going? If your lucky just broken rockers, if your not a broken and bent valves.
    Jul 2010
    not my car, girl said she had slowed away down and was almost at idle speed
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    A garage will remove the cam cover and check and replace the rockers, the timing belt and, assuming the water pump seized and broke the belt, that too. Really only after that can they see if the car will run, if not they will have to remove the head and see how many valves its broken or bent. I don't know if its possible to do a compression test through the glow plug holes or not.
    Engine : 1.9 CDTi
    9 times out of 10 it will just break the rockers.
    So replace the rockers, new water pump, new cambelt and rollers etc and that should be it.
    Jul 2010
    cambelt isnt actually nipped its frayed, and the were it has frayed on the inside the crankshaft pulley has worn the teeth away, any ideas why this is?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Seized water pump
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by RyanNI View Post
    Only one of two things I can think is the tensioners haven't been set correctly whenever it was last changed or there could be play in the crank pulley.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Think I was lucky then when mine frayed.....
    http://www.vectra-c.com/forum/showthread.php?t=144725
    Jul 2010
    brand new timing kit fitted 1,000 miles ago
  1. Z19DTH cambelt setting warning
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 25th April 2017, 03:13
  2. Water Pump / cambelt broken.
    By prettypriddy in forum Engine & Drivetrain
    Last Post: 24th April 2012, 22:48
  3. Cambelt Broken 1.8 club
    By athol in forum Engine & Drivetrain
    Last Post: 24th March 2012, 20:12
  4. Z19dth cambelt change!!
    By signum_rob in forum Engine & Drivetrain
    Last Post: 12th November 2011, 20:57
  5. 3.0V6 CDti broken cambelt
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2008, 20:38
z19dth timing after belt snapped
*@faiauto.com
