Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Help me - vectra c 2.0 dti - Limpin donkey mode... ;(
    Regular Member ShaunyB23's Avatar
    Dec 2011
    Birmingham
    Default Help me - vectra c 2.0 dti - Limpin donkey mode... ;(
    hi all,im new here so i hope this is in the right place
    well just swaped my astra 2.2 sri for a vectra 2.0 dti.. Thought it was a nice deal but that soon ended...
    I didnt notice at first,due to this being my first diesel,that the car was down on power..
    Well figured out on here that it is on limp mode [ Someone blocked the spanner light ]
    So i brought a new egr and a maf sensor and checked all the pipes,but nothing has changed,not even a little,..vrrooom? Just same old shepper van kinda diesal going on..
    [Sorry about the spelling,im abit thick with things like that.]
    I had the codes read which said egr and maf thats why i replaced them,but yet it still acting the same,is there anything else that is easy that i can try...i dont want to spend more money on it now because its already f**ked me off abit to much only had it a week
    Thank you for your replys...
    P.S - Also i read on here that when the heater only works on 4 you need a new resitor...So i got one of them,it works on the other settings but not powerful? Just like a gentle breeze of hot air on 3? Is this normal or something else gone pete tong?
    Thank you
    West
    with regards to you egr fault... do a search for vac system & check all pipes & tubes including connectors for any splits & or make sure they are connected properly.
    Dec 2011
    Birmingham
    Hi thanks for your reply. I checked the pipes but nothing. Apart from a small black pipe under the engine looks abut chaffed and the rubber connector is little spilt right at the end where it goes on the pump I think ( to the right if engine smallish round thing) could that be the thing. How do I replace it thanks
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Shauny , the round thingy at the end of your camshaft is the vacuum pump ..
    If the rubber connections to this or anyof the other subsequent connections are split then you have no vacuum in the system hence no advancement equalling engine wont rev .
    get yourself some 3mm silicone hose of e bay 3 meters is enough to do the whole engine should be £7 to £8 for the 3 meters
    Also check your vacuum actuators have been connected up properly there marked in and load on the top covers .
    and still loving it
    Dec 2011
    Birmingham
    Hi sorry to sound thick. But do I just buy the tubes or do I need the end bits
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by ShaunyB23 View Post
    Shaun all you need is the 3mm tube , then replace each section by cutting the silicone tube to length
    see the enclosed pic as an example though this is of a 2.2 dti engine the principle is the same
    and still loving it
    Engine : 2.0DTi
    Mileage : 73350
    and still loving it
    West
    If the tube is fine then all you need is a new connecting rubber, i remember this happend to me on my old Vec B dti sri, i happend to have a leangth of rubber tubing which i had previously used as a brake bleed valve, all i did was chop 2 inch off & use it... it worked a treat & is probably still the car today, 6 years down the line
    Dec 2011
    Birmingham
    Hi thank you for the reply and the link,my mate had some rube from when he did his gsi,fitted it all now,shame its not blue tho looks nice,i got yellow,bit bright...anyway the car feels like it wants to go now,but still wont go past 3k revs,it gets there quicker but not past it...Stupid car ...At the way it going i rather catch the ****y smelling bus then this tracktooor
    Any other advice? .... Please>
    Dec 2011
    Birmingham
    Tube* not rube :]
  1. The signum and the donkey sanctuary
    By shaun260589 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2009, 19:10
  2. I am a donkey!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 09:20
  3. i am a donkey..... (cd30 question)
    By lewisboss777 in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2008, 00:05
  4. the farmer and the donkey
    By ditchp in forum Comedy & Humour
    Last Post: 24th August 2007, 18:34
  5. Plastic doughnuts and the 3-legged donkey effect
    By SignumPhil in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2007, 14:02
