Results 1 to 10 of 20
Thread: can i weld up my dmf ???
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default can i weld up my dmf ???
    i wonder if any 1 has tried to weld the dmf ???
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Try it buy all means the I will help u find a new gearbox lol the answer you are looking for is yes u can weld it up but remember it's there for a reason and the gearbox will take all the force
    Sep 2010
    LEEDS
    so no judder? and it will be quiet?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Yes, although it will have to be welded the same all the way round, as depending on how goosed your dmf is, as you can get play in all directions, As far as im aware the design of the dmf changed, so it makes sence to just replace it with another dmf.
    mine makes a slight noise, but i'll just be waiting till my clutch starts to slip then i'll change it all.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Have a word with these guys mate, they could make you up a solid one. There just behind Costco. If its a good idea on a CDTi or not is another thing.
    Sep 2010
    LEEDS
    Quote Originally Posted by XPCobra View Post
    so why do they make solid flywheel kits for othere manufacturs?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    There solid though, if you could see a dmf you could see how welding it up is not really an option, balancing it alone would be a nightmare.
    Sent from my Sony Ericsson Xperia using Tapatalk
    West
    It has been done on some vag's with success... you have to get it balanced 100% right though, when my dmf had failed it had actually welded itself together, the lack of balance was causing the knocking noise.
    Just to add, you would still need a new clutch (a sprung clutch) if you had a welded or a solid fly... to take up the judder/vibration
    Engine : 1.9 CDTi
    Quote Originally Posted by Turbomanrony View Post
    Because they can.
    You can get them for transits and we have started to get them coming back after doing about 50k on the solid flywheel needing gearbox rebuilds.
    The vibrations from the engine are transferred to the clutch where they are absorbed. On a solid flywheel they are transferred to the gearbox and bearings.
    It seems some cars can survive with them for longer than others.
    Sep 2010
    LEEDS
    So really it costs alot eather way, its eather a bill for the gearbox or a bill for the dmf!!
  1. Exhaust Bracket Weld?
    By chrisf70 in forum Engine & Drivetrain
    Last Post: 29th December 2011, 09:15
  2. OK. Holts Rad Weld, or Bars Leaks?
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 21:25
  3. Can you weld Stainless Steel???
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2007, 23:10
do I need to my dmf on my vectra c
Can I weld a dmf on a insignia
welding my dmf to make it solid
welding a dual mass flywheel
weld dmf flywheel
weld dmf
Dmf to single mass by welding
dual mass flywheel welding
welding up dual mass flywheel
