Thread: outside temp sensor
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default outside temp sensor
    is the above fused? i have replaced the sensor after getting the letter f instead of a temp on the screen, but it still says f
    any ideas guys?
    cheers
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you checked its plugged in with the fog light wires to the body.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    I presume so as the fog lights work.
    Engine : 1.9 CDTi
    Mine was reading about 8 degrees to warm.
    Turned out the pin in the plug was corroded. Cleaned it and its now fine.
  1. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  2. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  3. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 17:35
  4. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
