Thread: Adding a second alarm LED?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Adding a second alarm LED?
    Given that the OEM alarm LED/switch is, IMO, located where you can't really see it from outside the car, has anyone on here added an additional LED in a more conspicuous place?
    I was thinking somewhere around the centre speaker area by the demister vents on top of the dash but haven't got a clue how to go about it. For obvious reasons, Haynes don't give you a wiring diagram for the alarm system .
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    I was looking into this, I was just going to disasemmble the alarm switch and extend the wires on the led to centre speaker location or interior mirror mount (like BMW).
    11 Post(s)
    Does it need to be wired into the existing alarm LED though.
    Many moons ago when I had my Mk2 Cavalier, I just bought a £3 flashing LED (with chrome surround) from the local motorist shop and wired it into the ignition switch and mounted it in one of the blank pop out panels next to the light switch. One wire was permanently connected to a live feed (via a small rated fuse) and the other wire was connected to the switched live. When the ignition was switched off the switched live dropped to earth and put the LED on.
    Simple, effective, and I didn't even have to fit an alarm.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    , I remember doing the same on the mk2 and 3 cavvys. Tandy stores were great for them.
    11 Post(s)
    Regular Member SRIDAN's Avatar
    Out in the Estate
    8 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : Z19dth + a Teapot
    Mileage : 94000
    Default wiring
    Quote Originally Posted by ScotsDragon View Post
    Hi
    Did you ever do this mod if so did you do the above?
    Danny
    East Ayrshire
    Trim : SRI XP1
    I had done this on my vec b. All it took was a red led, some cable and time! I fitted and led into my mirror with the led facing towards the windscreen, looked really good. Take out the alarm switch, you might need to even remove the facia to get in to the cable. Connected up a wire to the +ve and -Ve and run the cable to where you've mounted it. Job done, It will flash in time with the centre alarm switch
    Out in the Estate
    8 Post(s)
    Trim : Leather
    Mileage : 94000
    Thanks for that,will give that a go tomorrow seems easy enough.
    South east
    Those aftermarket alarm LEDs have been around for decades, and thieves know they're usually used on cars that don't actually have alarms, so you might be giving out a signal that your Vectra doesn't have a factory-fit alarm hence why you've resorted to adding a dummy LED to make it look like you have one.
    Out in the Estate
    8 Post(s)
    Trim : Leather
    Mileage : 94000
    Your right there but mt car is only used for shows the rest of the time its locked away in my workshop safe and sound...
  1. Adding to the alarm system
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2011, 18:34
  2. Adding Aux
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 10:52
  3. Adding a sub to the standard hu
    By neilb1 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2011, 21:24
  4. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
  5. Adding Sub and Amp
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 00:34
vauxhall alarm switched live
how to wire additional alarm led astra j
