Thread: No power at the Washer pump
    Regular Member DTI Dave's Avatar
    Nov 2011
    st annes
    Default No power at the Washer pump
    I dont seem to have any power at the washer pump end... any particular reason for this?
    wipers work fine. could this be a fuse or is it on the same circuit as the wipers.
    Engine : 1.9 CDTi
    Does sound like a fuse.
    Did you have frost and try squirting the screen as that blows the fuse on the Corsa C's so might do the same on the Vectra's
    Nov 2011
    st annes
    no, its not worked since ive owned it. i will check fuse tho.
    Nov 2011
    st annes
    fuse is still good.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Defiantly no power and not the pump gone?
    Nov 2011
    st annes
    definatly no power at the pump, and tired 2 working pumps
    May 2012
    Hemel Hempstead
    Hi did you find what was the problem? I am having the same problem - no power at the washer pump. Washer fuse is ok.
    The wiring diagram points to relay K9_X125, but I seem to unable to locate this relay.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Quote Originally Posted by blacksignum View Post
    Threads 4 years old mate
    Full Member
    Timisoara, Romania
    6 Post(s)
    Trim : Estate
    Engine : Z19DT
    Mileage : 210.000
    Old but the problem might not be solved yet...I have similar problem with the washer pump for the headlights. It worked fine until 3-4 days ago when I tried to get a wash for the headlights. It squirted a bit and then stopped. The fuse is ok, changed even the relay (had a new one for spare)...no joy. Tomorrow I will check to see if any power actually gets to the pump or the pump itself is busted. Anyway, I heard several colleagues on the Romanian Opel forum complaining about similar problems and they solved it by changing the UEC...maybe @plasma could advice on this? Is there any particular reason why all of a sudden power just won't go the the pump, due to UEC failure?
    May 2012
    Hemel Hempstead
    Alin,
    I think you are onto something here, at least in my case.
    All cars have Windscreen washer pump - wired via relay K9 (Haynes manual) and
    Optionally headlights washer pump - wired via relay K7 (Haynes manual).
    Relay K7 (if headlights washers fitted ) is easily located in the engine fusebox - it is a white relay (part number GM 24 438 885).
    However I cannot not locate relay K9 anywhere in the fusebox - and I am not coming to the conclusion that that relay is located within UEC (Underhood Electronic Control Module) itself.
    Therefore no power at the screen wash pump may be due to the following:
    1. UEC - needs a reset.
    2. UEC is faulty - needs replacement
    3. The wiring between UEC and the windscreen washer pump is damaged need checking.
    It seem that UEC is also controlling relay K7 (for headlights washer pump). If the module is malfunctioning the pump operation may be also affected.
    What did you find on the Romanian forum? Do you know how easy to remove engine fusebox and get access to UEC? I understand that it is located somewhere underneath fuse panel.
  1. Washer pump removal....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 23:40
  2. Washer bottle pump
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 16:02
  3. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  4. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
vectra c washer pump relay
