Thread: no smoke, no poke.........
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    Default no smoke, no poke.........
    this is what i tell people when i start the car from cold, but now its getting embarrasing, ive got a 2004 2.0 dti and when i start it from cold ie mornings and after work, it stuggles to fire and when it does it gives a good puff of light grey smoke , like i say this is getting embarrasing now as the lads at work all start coughing and spluttering when i start the car to take the plss. lol any ideas to help remedy this.
    had new egr valve in march,
    it has been decatted
    having new plugs on thursday.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    see what its like with the new glow plugs fitted. If it has high miles then try thicker oil like a 5w 40
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Next thing i'd try would be leak off pipes buddy
    Jul 2011
    north lincolnshire
    cheers milage has just hit 100,000miles, only serviced a month ago,
    john, what do the leak off pipes do?
    taunton
    your leak off pipes are fitted to the injector if they are spit it wont start very well. when i had a 2.0 dti it stopped and all the fuel went back to the fuel tank and would not start at all. I change the pipes bleed the system it was all fine then.
    West
    If battery is ok, then start with leak off pipes, then move on to starter motor... my old 53 plate dti fired up first crack in the coldest of weather.
    East Midlands
    My 2.0dti does exactly the same and it's on 107,000 although its tends to start ok in the mornings,i put it down to the outside temp not being quite cold enough like today it was 7c on my temp gauge and leaving work it took 3 goes to start it,an i also end up with a puff of grey smoke accompanied with the tell tale smell of unburned diesel.
    Some time ago on the forum,maybe 3 or 4 years ago someone came up with the idea of by passing the auto glow plug switch on for a manual switch that you control and not the car,ideal for days like today anyway can't remember who it was its that long ago.
    West
    ^^ you could always try unplug the temp sender for the first fire up of the day...
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Its more than likely injector seals or leak off pipes, very cheap to replace if you can do them yourself, i had to remove the camshaft to change the last set of injector seals.
    Jul 2011
    north lincolnshire
    How would that be done
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. more smoke
    By andy76 in forum Engine & Drivetrain
    Last Post: 22nd June 2010, 11:34
  3. HELP! Car has come back from 40k mile service with no poke
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 16:24
  4. A pig in a poke?
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2008, 23:40
  5. no smoke.........no poke.........
    By dervdoc in forum Quick Photo Album
    Last Post: 16th May 2007, 07:13
