Thread: Fuse box diagram with captions? anywere in the forums?
    Regular Member DTI Dave's Avatar
    Nov 2011
    st annes
    Default Fuse box diagram with captions? anywere in the forums?
    hi, im looking throught the search part on here and cant find a fuse block diagram.... as in a pic of the fuseblock with captions as to what fuse does what...
    is there such thing on here...
    help please.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Similar to those in the Owners Handbook????
    http://www.vauxhall.co.uk/content/da...nual_Jul07.pdf
    Pages 248 - 251
    Nov 2011
    st annes
    oooo thanks
    Year : 55
    Mileage : 92,000
    np
    Hope you get your lights sorted
    Nov 2011
    st annes
    thanks, got other problems at the mo..... i was checking all the fuses so pulled em out 1 by 1. and somewere along the lines i think i put a fuse back in the wrong hole, as now my brake lights are continuously on when the ignition is on idiot lol
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Sounds like you have not put a fuse back in the rear driving lights. The Vec uses 2 bulbs for the rear driving lights and one for the brake light, so three in total, when one fails another will take over the job of the failed bulb, it may look like all your lights are working but you will still get a bulb warning on the dash.
  1. Captions Required - Rutland Water Photo
    By Ian T in forum Comedy & Humour
    Last Post: 11th March 2008, 18:16
  2. Fuse / Relay diagram for Vectra (1.8 SRi)
    By djhallam in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2008, 16:02
  3. captions
    By jonno_07 in forum Comedy & Humour
    Last Post: 21st October 2006, 11:17
  4. Captions Please!!!
    By AJA in forum Comedy & Humour
    Last Post: 3rd February 2006, 00:14
vectra c fuse box diagram
vectra c rear fuse box diagram
vectra c where is the fuse for egr
vauxhall corsa fuse box layout
https:www.vectra-c.comforumshowthread.php151543-Fuse-box-diagram-with-captions-anywere-in-the-forums
vectra c rear suspension diagram
vectra c boot fuse diagram
Vauxhall Vectra C Fuse Box Diagram
corsa 2006 fuse box diagramopel corsa c fuse box diagramfuse box corsa c diagramcorsa c fuse box diagramvectra c diagramvauxhall vectra 06 fuse box location2011 vauxhall vectra fusesvectra c diesel fuse box layoutvauxhall corsa 2005 fuse box diagramvauxhall vectra fuse box layoutvauxhall vectra fuse box layout 2005fuse box location on a Vauxhall Vectra 20062008 vectra c fusebox 2 locationvauxhall 1.9cdti 2007 fuse layoutvauxhall zafira fuse box diagram 2010vauxhall zafira fuse box diagram 20072005 vectra fuse box diagram
