Results 1 to 10 of 18
Thread: Fitting Sub this week and....
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default Fitting Sub this week and....
    Despite the freezing weather conditions, this week i'm going to attempt to install my 1000w active sub in the boot of my Siggy. These are my questions:-
    What size cable (mm2) should i be using for the 12v power from the battery?
    Where is a good place to connect the GND?
    There is a fuse on the sub itself do i need one on the cable also?
    Can i take the remote on 12v from the cig lighter (IE so the sub turns on when the ignition powers up)?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Bump
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cant rember the size cable I used, but the thicker the better
    You can use a boll from the rear seats (just rub away any paint) as a ground
    Yes alwyas have a seperate fuse as clote to the battery as possible. This also means you can remove the sub with out leaving a live wire.
    Yes you can use the cig lighter, but remember this means its on when ever the car is on, so may be worth fitting a seperate switch. You can also get variable gain controllers with remove lives on them.
    P.s If anyone feels any of the above is wrong please correct me as ill probably be fitting a sub in my latest vec at some point
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    4 gauge minimum for the power supply and the ground. Always put a fuse within around 12 inches of the battery.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Cheers guys. invaluable as always. I was going to go with all of the above, the only difference was i was going to find a gnd on the rear fuse box.
    4 guage? Thats about 22mm2? Isn't that a bit excessive (& expensive) for 1000w?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    There's two earth points in the boot, one each side fella. Just earth the amp to that. Run the 4 gauge power cable direct to the battery though and as said by someone else, fuse it at the battery end too.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by BigWilko View Post
    Nope. First system I did I put in 8 gauge, them a while later changed up to 4 gauge, system was notably better with the larger cable. Its one of these jobs that is best done right the first time. Had a quick look on ebay and its only about £2.99 a meter which is pretty good imo. You'll need about 5m I would think. Better ordering too much than ending up having to join in another piece.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    OK mate. Just wanted to check. I'll take your advice as 'superior knowledge' on this one. Off to buy some then.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I used 6 mm stranded 3 phase cable for mine from work ha lol
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by paulvectrac View Post
    Nice, I got some 2.5mm 4 core stranded speaker cable kicking about. Might connect all the cores together for 10mm. You think it'll go through the grommet in the bulkhead behind the glovebox?
  1. What a week.
    By Grumpy1954 in forum The 'Off Topic' room
    Last Post: 28th June 2012, 19:23
  2. little mod done last week
    By baz2003uk in forum Styling
    Last Post: 13th June 2012, 07:56
  3. Very Good Week/Bad week
    By Ben R in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2011, 19:43
  4. pig of the week.
    By coylo5 in forum General Chat
    Last Post: 16th January 2008, 20:33
