Results 1 to 10 of 19
Thread: Think my thermostat has gone
    Regular Member e55ex_rob's Avatar
    Sep 2011
    Basildon, Essex
    Default Think my thermostat has gone
    Hi all,
    As title states and i know this prob comes up all the time. Had a little look about and im sure it has gone, but just wanted to be 100% before i do anything.
    I have a 1.9 CDTi SRi 150
    I get hot air from my vents as normal, no actual problems with the car what so ever. Only thing that makes me think the thermostat has gone is that the temp gauge dosent seem to move at all.
    If it does need replacing im guessing i need part no: 55203388
    But as mentioned i get hot air no problems.
    If anyone can shed a little light that would be great
    Rob
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    I would be interested to know too because mine's doing the same, occasionally creeps up to 85 when in traffic but otherwise doesn't move. Still getting warm air from the vents too.
    Sep 2011
    Basildon, Essex
    Quote Originally Posted by Samdy Gray View Post
    yeah mine has done the same time to time. creeps up to 85
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    and me too.,
    my understanding is that the blowers still blow warm but takes longer to get warm air?
    i maybe wrong
    South east
    Thermostat problem: Temperature needle takes ages to move off the bottom reading, and when you drive along a motorway the needle goes back down again.
    If the needle never ever moves, even when sitting in traffic for 20 mins, then it might be a temperature sensor fault.
    Sep 2011
    Basildon, Essex
    Quote Originally Posted by Rebellion View Post
    im guessing best thing to do is take the car for a 10 min drive then leave it running on the drive for 20 mins to see if any movement happens?
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    in the winter with the low temps my gauge hardly moves. but i still get nice warm air through the blowers
    in the summer it works as normal but i will say it doesnt go up as quick as all the other cars ive had
    Warm air is a good thing at least you know theres water in there & its circulating as it should
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Yup defiantly a failed thermostat. At least these days they fail open, instead of closed.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    yepsame symptoms as mine, replaced the lot inc anti freeze job done
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    I hd the same issues with mine,heaters were red hot but the gauge had a mind of its own.
    I would get it done before it gets really cold out there.Also you should see a few more MPG aswell as the car is running cold all the time
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
