Results 1 to 7 of 7
Thread: can someone give me a step by step guide to...
    Regular Member taffy bhoy's Avatar
    newport
    Default can someone give me a step by step guide to...
    removing the ashtray and cubbyhole under stereo and any other bits that i need to, so i can access the diagnostic port to add the extra 2 wires for the tid to gid conversion. can't see an obvious way of removing them and i dont just want to pull them and break something lol
    cheers in advance
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Taffy you need to start at the back with the arm rest centre console, then work your way forward. 4 trox bolts hold the arm rest on, remove the rear ashtray/aux panel to get to them, then 2 screws hold the console down at the back. Remove the coin or cup holder to get to the other screws. Centre console is held on with 2 nuts, 1 either side behind blanking plugs in each front foot well. I honestly cant remember if you need to remove the stereo or not. Its pretty straight forward, centre console around the was a bit trickier tbh. I think it only took me about an hour or so to dismantle, do the wires and replace everything.
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Errrm, to add the two wires to the ODB plug you don't need to do any of that.
    Same answer as I gave you on VVOC Gareth
    Lift the ashtray centre and the ashtray out to reveal the plug, push the clip in either end of the plug and push down and the plug comes out underneath the metal bracket it sits in, there's enough slack cable (just) to get the extra wires in.
    Pop the centre vents out and drop your cables down behind the switches to the plug, if you need a bit more access at the bottom you can pop the bottom cubby out, it's not held in with anything, just pops out.
    Simpleess.
    newport
    lol, so you did, i was looking for your post earlier but i couldnt find it, wasnt sure what thread it was in, thanks again both
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    I tried that Ian, I couldn't get enough slack or even enough room to see any of the back of the ODB plug
    Ely, Cambridgeshire
    63 Post(s)
    Here's the post in the TID to GID thread with all the pics from when I did mine in my old SXi. Might help I dunno
    http://www.vectra-c.com/forum/showpo...&postcount=490
    newport
    cracking pics, will try that way when i do mine. how did the ashtray unit come out? i can wiggle mine about, so i dont think its screwed in, do i just pull it up or will i break something lol
  1. Two questions before next step.
    By mat_splat in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2012, 22:27
  2. First step...
    By weverall in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2011, 20:43
  3. another step closer !!!
    By ditchp in forum Styling
    Last Post: 24th February 2011, 12:57
  4. step by step guide
    By dezwez in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2010, 17:30
  5. Looking to step up, what can you tell me?
    By Vectra 'a' nut in forum Introduce yourself.
    Last Post: 19th November 2008, 22:26
vectra door hinge crack
Vauxhall signum door creaking
