Thread: loud cracking noise when opening/closing door
    Regular Member marky2027's Avatar
    Northumberland
    Default loud cracking noise when opening/closing door
    This is getting worse. On the driver's door when I open/close it at a certain point it will make a loud cracking noise. I have smothered all the hinges in grease and WD40 but it still does it. I think it is the larger metal strap in the middle of the door that is making the noise. Any thoughts?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    yes check strap there is an easy how 2 fix in the how 2s
    Northumberland
    Spot on. Thanks mate!!
    Jun 2009
    Chelmsford
    Same prob few months back, its your check strap, easy fix!!
    South east
    And grease/wd40 is what starts the problem in the first place.
    newport
    undo bolt holding the strap to the a pillar, spin the strap 180 degrees, so its facing the wrong way, undo the 2 nuts holding strap to door, push the strap into the door a bit to release the 2 bolts, then spin the whole thing 180 degrees again, so its facing the correct way again, then do all the bolts up, job done, takes 2 minutes
    Northumberland
    Quote Originally Posted by Rebellion View Post
    How come??
    newport
    i believe it stops the ball inside it from rolling, it glides on the grease and creates a flat spot on it, rather than rolling smoothly over the bumps in the strap
    Engine : 1.9 CDTi
    The check strap is designed to roll on 2 rollers inside.
    By greasing it the bar just slides and wears away the nylon bush.
    It does say in the service book that you dont grease the check strap.
    Northumberland
    Every day is a school day!!
  1. Driver's door not closing properly
    By donkmeister in forum Bodywork & Interior
    Last Post: 11th November 2012, 15:31
  2. Drivers door.nasty noise when opening & closing.
    By Dobs in forum Bodywork & Interior
    Last Post: 5th November 2011, 01:16
  3. Rear creaking/cracking noise
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 23:46
  4. cracking noise?
    By tonyblade in forum Bodywork & Interior
    Last Post: 11th June 2009, 00:06
  5. FR 1516: C-Pillar - Cracking Noise (Vec C)
    By Duncan in forum Body & Body Equipment
    Last Post: 25th June 2005, 15:35
