Results 1 to 2 of 2
Thread: Z20NET oil issue after replacing turbo! :@
    Aug 2011
    Northfield, Birmingham
    Default Z20NET oil issue after replacing turbo! :@
    right guys, bought myself a 03 reg 2.0T (z20net) with the turbo knackered, basically, wasnt boosting and exhaust was full of oil, took it too a turbo specialist, he confirmed it was knackered so i had it reconditioned. when removing the turbo i removed the bottom intercooler pipe (underneath) and it was very dry from oil, so it had just dumped it into the exhaust,
    Anyway i refitted the turbo, and now for some reason, it appears to boost and drive fine, but then upon inspection after a 5 mile very steady drive, the engine oil has disappeared! found out its gone into the inlet system and its full of oil! which it was not before! :S
    Any ideas at all guys?
    Baffled! i dont want to drive it now due to the fact all the oil in the inlet will get picked up by the turbo and knacker it up again!
    South east
    If the pipe under the engine had oil in it then so did the intercooler (and throttle body) - did you clean them out?
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Replacing a turbo on CDTI 150
    By Dave78 in forum Engine & Drivetrain
    Last Post: 17th August 2014, 10:44
  3. Issue with replacing broken heater control
    By Trantor in forum Bodywork & Interior
    Last Post: 18th June 2012, 21:46
  4. Z20NET starting issue
    By sandy white in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2011, 22:44
  5. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
