Thread: Dash on blink!!!!
    Aug 2009
    Ascot
    Default Dash on blink!!!!
    Since the cold weather has arrived I keep on losing my dashboard!!!!
    I have read some threads about fuses & abs plug
    1. I can only see a fuse box under my bonnet, and not inside the car??
    2. Where is the and plug so that I can clean it?
    Nick
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    There are three fuse boxes in a Vectra. One under the bonnet next to the battery, one behind the little pull off door on the passenger side end of the dash board and one in the boot on the passenger side.
    The ABS unit is behind the battery under the bonnet, look for a big square thing with metal pipes coming out of it and a big electrical connector on top. You can just see it top right of this picture behind the battery box.
    Although dash being on the blink is usually one of the fuses in the passenger side fuse box. Sorry don't remember which, but someone will soon tell you.
    Fuse no 17 in side of dash ian
    Sent from my iPhone using My thumb
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Cheers Mark, my brain was saying 7 for some reason, just as well, I let someone else answer that bit lol
    Aug 2009
    Ascot
    Tried fuse 17 & 10 but no joy, it only seems to do it when cold!!!!!! Also what does cim stand for?
    Nick
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by s2yob View Post
    Nick
    Column Integrated Module. That's about all the help I can be on this one - sorry Nick .
    Are you saying the speedo and rev counter and all the warning lights don't work?
    Lastly, and you proably have, do a search on here for "no instruments" in the advanced search function, search "thread title only".
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Nick - have you tried disconnecting the battery for an hour or so?
    Aug 2009
    Ascot
    The dashboard and all the lights on it, bar the eml go out and only come back on after driving for about 20 mins and turning ignition off then back on again. It only does it though when the cold/icy weather is here
    Nick
    Regular Member Mopar Man's Avatar
    herts
    I have had this problem and as said you need to disconnect the battery then reconnect. This will reset the dash mod.
    Aug 2009
    on the hills
    i have this on my `02 and i`ve checked all the recommended things on the forum and the only thing that i find to work straight away is this and i`m NOT joking, are you ready?
    just open and close the drivers door, no need to stop either just do it and all the dash comes back from planet zog working fine, honest!!!!!!!!!!!!
  1. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  2. Alpine CDE-113BT On the blink!?
    By shiver2k11 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd April 2012, 20:16
  3. Air Con on the blink.
    By WilliamLX in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 21:22
  4. Air con on the blink?
    By Chop Suey in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 15th April 2010, 19:14
  5. Steering Wheel controls on blink
    By Al Adams in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 12:03
