Thread: Odd hid issue
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Odd hid issue
    guys i have hits fitted to my car. Every so often when i switch it on and then switch on the headlights the abs and t/c light stay on and when i restart the car and then rev the engine then switch the lights on at the same time they don't come on. I thought this could be the hid set so i bought a full new set and went from 50w to 35w in case it was an issue with that. It still happens and is driving me nuts. As i said its not every time tho but a lot of the time. Also the car sits all week in the garage unlocked so as to not put too much drain on the battery. Anyone any ideas what could be going on?
    Engine : 1.9 CDTi
    Where are the ballasts mounted as they can interfere with the Canbus.
    Aug 2007
    Lisburn, N.Ireland
    under the headlight unit them selves attached to the unit as there was a perfect cutout in the plastic
    Engine : 1.9 CDTi
    Mine are there too with no issues.
    Cant help sorry.
    Aug 2007
    Lisburn, N.Ireland
    the old set were fine for ages then this started to happen so i changed the whle set incase but its still there how long will the battery last in case its that?
    Glasgow
    Sounds like your alternator is on its last legs and isn't charging as it should.
    Aug 2007
    Lisburn, N.Ireland
    how can i check this then?
    Jul 2011
    UK
    Year : 06
    Bad ballest used to happen in 206 I had abs airbag n management light turn car off back on would be fine
    Aug 2007
    Lisburn, N.Ireland
    thats what i thought so thats y i bought a brand new full set and no difference different model and everything and bought from hid direct for a vec-c
  1. Air con issue
    By harts1.9design in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:26
  2. hid issue
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 10:30
  3. Hid a serious issue ?
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:28
  4. DAB issue
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 01:12
  5. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
