Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi with refernce to my last thread bout vectra 2.0 dti using lot of diesel , the car takes about 8 miles for temp gauge to move of bottom of gauge could this be some of problem
    Full Member paul.sessions's Avatar
    leighton buzzard
    mines the same diesels always take longer to heat up.
    Jan 2010
    norfolk
    Default vectra dti
    thats ok then thought it was faulty
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Temperature gauge works on coolant temperature.Takes at least 5 miles to move.
    exeter
    for the use of a lot of diesel . you said you have change your egr valve . but someone has told me on here about the inlet maifold . that it should be cleaned as well as the egr . because mine keeps going rubbish on fuel and the egr fault show up . here is a how2 . i going to try that when its dry .
    http://www.vectra-c.com/forum/showthread.php?t=145119
    West
    does it stay up to temp, once it gets there
    Jan 2010
    norfolk
    Default vectra dti
    i cleaned inlet manifold few weeks ago , and temp gauge stays up while on move but goes down to 80 in traffic
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
