Results 1 to 10 of 16
Thread: 3.0 cdti wont start
    May 2011
    belfast
    Default 3.0 cdti wont start
    Came out to car this mornning wont start, never had any problems before, Falshing spanner light on dashboard. Put my mates snap on Diagnostic on and it comes up with p1610 Immobiliser fault.
    What do I do now ??????
    Bristol
    Get him to reset the immobilizer. And reprogram the keys. If he has the latest snap-on software he will be able to do it.
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Quote Originally Posted by Evilyoda View Post
    If you have had the Ignition key a part, check the ICU "chip" as not fell out....
    Bristol
    Code P1610 is immobiler is not set . ECU has been reset and need programing.
    May 2011
    belfast
    Quote Originally Posted by sb1uk View Post
    He is not a mechanic by trade not even sure why he has this, anyway i know he would not know how to do this
    May 2011
    belfast
    how does it reset just sitting in the driveway overnight ???
    Bristol
    Well I do not know but that is what the VX tis says. either you mate pressed the wrong button. I do not know but there is only one way to sort it get it reprogamed from the start.
    Bristol
    This is what is said on tis for P1610
    • The engine control unit is in reset state.
    Effect:
    • Engine operation is impossible.
    • The Service Vehicle Soon (SVS) Pictograph flashes
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If he has snap on mate. It's very easy to do. By following the instructions on screen.
    But the car pass is required.
    Immobiliser fault on my car (2005MY) should be a car and padlock
    Nothing for just a spanner, so presumably car and spanner?
    Ironic the same fault can show either
    Page 55 of my handbook advises to restart sequence :
    Insert key, remove key, insert key, then start engine
    If fails, use spare key
    If the spare key works, then retest with the other key, you should find it then resynchronises
    Equally, did the central locking working with the failed key?
    Mine loses its code typically once every six months, so have to unlock the door, alarm goes off, insert key and restart sequence
    If it happens twice in the same day then I replace the battery
    Sounds to me like the key you are using has lost its code
    A fresh battery should solve that
    My previous Ford Mondeo Mk3 had a similar process, although it was not published in the handbook (found this was insert key, press clock, press key, wait)
  1. Replies: 9
    Last Post: 15th January 2013, 14:16
  2. Replies: 12
    Last Post: 25th May 2012, 19:54
  3. CDTI Engine wont start
    By dag1 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 20:11
  4. cdti 150 wont start, just in the morning
    By peadar in forum Diesel Engine related
    Last Post: 12th March 2010, 21:27
  5. Signum 3.0 cdti wont start
    By Gumball 3000 in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 20:06
3.0 cdti vectra wont start
