Thread: Main Beam issue
    Regular Member Cruize's Avatar
    South East
    Default Main Beam issue
    Took my Veccy for it's MOT and failed on the offside beam being too high. Simple I thought and went about adjusting it. Parked the car up to a wall so I could level it to the nearside but I can see a distinct difference between the beams.
    The Nearside lamp which is fine appears normal but the offside in comparison looks like the beam is split?? If that makes sence. You can see where the main beam is pointing but there appears to be a bright 'haze' above it which makes it appear like the beam is split?
    Any ideas? Running bog standard Halogens.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try changing bulb with other side.
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Could it be that the bulb has not been installed correctly and is sitting at a funny angle???
    If the car is a prefacelift could it be that one of the adjusters (for when driving in france) has moved and is not on the right setting???
    Adjuster can be seen here:- http://www.vectra-c.com/forum/showthread.php?t=72547
    Just thinking out loud and throwing a few ideas your way
    Good luck getting it sorted.
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    South East
    Possibly, I'll have a look at that.
    I've ordered some Xenon's to throw in there so i'll look at the bulb 1st and if thats not dodgy then i'll look at the adjusters. Could be just that its not seated right, my old man has got it at the moment so I havent actually looked at it since but i'll give this a go.
  1. main beam question
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2012, 20:22
  2. Main beam bulbs
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 12:29
  3. Hids in the main beam...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 20:50
  4. Are the h/l and main beam bulbs the same ?
    By simac in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2006, 22:13
