Thread: Serviced car, now emissions warnig light is on :s
    Nov 2011
    Newcastle upon tyne
    Default Serviced car, now emissions warnig light is on :s
    Hi all. Today I done a service on the vectra. Oil, oil filter, air filter, plugs and pollen filter. But now when I came to start car the car the emmisons light is staying on. Constant light not flashing. The car is a 1.8 04 plate petrol. Thanks for looking.
    Cheers rob
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    And it wasnt on before you started the service?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Are you sure you have plugged the MAF sensor plug back in? _ make this mistake myself. Also it could be that having changed the filters etc, the ECU is seeing a big difference, so thinks there's something wrong. The easy way to test is to disconnect the battery for 30mins to see if the light goes off, or use a code reader.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by ghostrider View Post
    Nov 2011
    Newcastle upon tyne
    Hi yeah I did have maf unplugged but when idealised it was out I put it back in. Old oil and filters were manky so that's what I thought that te ecu is regestering a massive change. Car still drives great and is very responsive still so must be the ecu being stupid lol. Will disconnecting the battery for half hour not screw upte immobiliser etc?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    No it wont screw up anything. Before you do it though do the Pedal Test and see what fault codes are stored.
    On another planet
    Engine : 2.0
    Quote Originally Posted by Hodgy View Post
    There you have it - the fault with the MAF sensor unplugged has been stored, so the light is on. It'll go off after around 20 starts, or you can just disconnect the battery for 30 mins. Remember to open the windows all the way down and back up with the switch to reset them after you reconnect the battery.
    Nov 2011
    Newcastle upon tyne
    That's what it was the maf fault code. Went to nip out before and it went off so thank god. Had me worried. Thanks for all your help people. Not used the this modern electronic sensor systems. Cheers again.
    I find if you wait about 2 hours then restart the warning goes away
    I learned that one from the dealership, where they have to disconnect the MAF sensor, rather than mess with TECH2 they just make the customer wait...
  1. Emissions Light Help!
    By LadOnTractor in forum Engine & Drivetrain
    Last Post: 24th July 2011, 08:53
  2. emissions light
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 23:34
  3. Service light 'on' - only serviced 3 months ago!
    By snapsnap in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 23:04
  4. Emissions Light
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2008, 07:49
