Thread: EGR and drilled blanking plate.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default EGR and drilled blanking plate.
    There's some old threads kicking around on the subject of drilled blanking plates but not anything up to date.
    I just wondered what your experiences were/are -are you still using them, how many miles you've covered with a drilled plate, pros & cons etc, etc..
    Having fitted one with 2 x 8mm holes yesterday, the EGR chatter and whoosing has stopped, along with my misfire. Will have to suffice until stealer can check for updated EGR software .
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mar 2007
    Sheffield
    Quote Originally Posted by gtr1000 View Post
    did you make one or did you buy it from somewhere? a link would be awesome as im keen to do this next
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Celes View Post
    And it's Christmas .
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by zerocool View Post
    I made it out of 2mm thick aluminium plate. Others, in the early days, made it out of a flattened Pepsi tin (they said Pepsi cans were slightly thicker, certainly not 2mm).
    Celes (above) also made one I believe. If you're not in a rush, I could cut a blank one out for you in the new year, then you could just drill the centre holes to suit what you think. I use a jig saw so it won't be anything fancy but it'll do the job.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Mmm, I may look at doing one for my Z30DT, I'm going to get the car remapped but can't decide who or where but was thinking about doing this a while ago, along with cleaning out the inlet manifolds/piping etc.
    Struggling to find the time at the minute and I use the car too much to take it off the road for a week while I do it.
    GTR1000, why not post up a template of the plate you made, we'll ask it to be made into a sticky, again, it builds a good knowledge base.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Lee, I used the old metal gasket as a template for the new drilled plate. The new plate has to be the same dimensions as the old gasket as the bottom right hand corner is a tight fit against IIRC, the inlet manifold.
    Below is a pic of the original gasket but it's hard for me to dimension up due to it being oval.
  1. Egr Blanking Plate
    By vectra19 in forum General Chat
    Last Post: 5th June 2012, 20:37
  2. Egr blanking plate
    By morrisseyno1 in forum Troubleshooting
    Last Post: 10th September 2011, 20:49
  3. Egr blanking plate
    By baz_cdti_sri_150 in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:51
  4. blanking plate
    By lordreeson in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 12:59
  5. irmscher style drilled alloy foot rest plate
    By ditchp in forum General items for sale
    Last Post: 10th April 2009, 15:32
